It says Local Nucleus Service at the top but does nothing when i try to launch. There appears to be no server in the side panel under Omniverse.
When i click on add server and type in localhost, an Authenticate window pops up
For some reason no credentials that i have made with this entire process seems to log me in. no email address no usernames seem to work. I am not typing anything in wrong because i can log into the omniverse app just fine, and the website and anything else related to this, but the localhost doesnât accept any of these. Am i missing somthing?
@luke101 i am just a fellow OV user, so take what you will with the following input. while i havenât encountered this issue, iâd like to confirm the exact issue you are expressing.
if inclined, you could try uploading your launcher log file for further investigation in case itâs related to something else altogether. you can find the .log here:
Windows - %userprofile%\.nvidia-omniverse\logs\launcher.log
You just saved me! I saw a few threads on this topic but none mentioned a âfallback loginâ using admin and admin for both username and password. This worked straight away. so happy. Thanks a bunch!
to clarify, the nucleus localhost server login should be the one you have set up during the nucleus service installation. youâd get the Create Administrator Account prompt after clicking on Add Local Nucleus Service:
and, i am honestly not sure why some users experience odd login behaviors while others seem to have no problem. regarding the fallback, itâs actually in the official doc, but itâs quite hidden and can be easily overlooked on the first go-around:
Thanks a lot! Your work is fantastic too.
I have been interested in the Omniverse for some time but never l been in a position to get into it until now. I will probably try my next animation using it to get to grips with it.
Sorry, i found the issue, a few months ago, i used the cmd commands ânetsh int ipv6 set glob defaultcurhoplimit=65â & ânetsh int ipv4 set glob defaultcurhoplimit=65â which can cause issues, i replaced â65â with 128 and it works great now, also i disasbled proxy but that didnât fix it, âTTL 65â was the problem. (I used it to bypass internet throttling but i will have to reconsider this in the future) For now i want to thank you for the quick help.
