Windows 10, Quadro RTX 5000, 466.11.
I had been using Omniverse create and view on this system for about 3-4 months. On Monday, there was an option to update Nucleus which I started (before I noticed the outage warnings). Needless to say, that update failed. I ended up with the apps/launcher/etc, but they could only access local files, my local Nucleus was out to lunch. So, I downloaded and ran the launcher-cleanup tool and let it delete anything it wanted to (data and all). I then downloaded the latest launcher installer. I could install all the apps, etc, but I ended up with this for Nucleus:
The “add local…” button does nothing when I click on it. There is only the attached launcher.log file in the .nvidia-omniverse directory.
launcher.log (9.3 KB)
What is worrisome is that there is no AppData/Local/ov directory at all.
< quick update, I was able to install “drive” from the exchange and it created the ‘ov’ directory with drive in it, but overall the original problem still remains >
What do I need to do to re-install Omniverse on this machine?
