Unable to start Local Nucleus Service
Hello
I set up the Omniverse Launcher on Windows 10 with omniverse-launcher-1.9.8-win.
After install the Local Nucleus Service from the launcher, the Nucleus not starting and there is no logs out.
After reboot the host,
Launcher run as a administrator.
cleared the local nucleus cache and application cache, restart the omni-system-monitor.exe.
attached launcher log and nucleus-setup log
launcher.log (273.9 KB)
nucleus-setup.log (16.8 KB)
@jhy2 i would suggest you try a few things:
  • Windows defender was fully disabled during the installation and running service check.
  • Tested windows machine is VM on vmware ESXi 7 host with internet connection
I tested same version of launcher on the baremetal windows 10 enterprise host, then the local nucleus server works fine. (without any port configuration on windows defender)
I can’t find any difference between them except the physical machine and VM.
Any ideas?
Is this a self-hosted VM or are you using it on a cloud provider? This sounds like it may be a VM setting somewhere. We test Nucleus Workstation on bare metal for the most part, we do not test against VMs
VM was created on VMware ESXi 7 host. (7.0.3)
Additionally, the Enterprise Nucleus(docker compose way) on Ubuntu 22.04 guest VM on same ESXi host works fine though.
I found the problem was L40’s vGPU is not supported on ESXi7, but ESXi 8 would be work.
I still can not found any solution on using passthrough mode.
