main platform mode DTB
Hi Shane, data capture has issue, I wan to confirm the port bonding setting is OK firstly
[ 4704.979218] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4704.985693] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4704.995847] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000008
[ 4705.004624] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x00000008
[ 4705.013426] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4705.022186] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x00000004
[ 4705.030990] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000cc88
[ 4705.038964] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000cc88
[ 4705.251597] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4705.258286] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4705.269541] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000c
[ 4705.278369] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x00000008
[ 4705.287223] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4705.295955] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4705.304813] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000cc88
[ 4705.312702] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000cc88
[ 4705.599453] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4705.606167] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4705.617865] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000c
[ 4705.627125] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x00000008
[ 4705.635943] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[ 4705.644697] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4705.653464] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000eec8
[ 4705.661380] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000eec8
[ 4706.067738] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4706.074435] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4706.084568] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000c
[ 4706.093766] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x0000000e
[ 4706.102602] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[ 4706.111362] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4706.120131] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000eee8
[ 4706.127981] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000eee8
[ 4706.339480] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4706.346129] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4706.358455] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000c
[ 4706.367343] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x0000000e
[ 4706.376261] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[ 4706.385119] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4706.393988] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000cc88
[ 4706.401940] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000cc88
[ 4706.611338] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4706.618104] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4706.629522] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000c
[ 4706.638407] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x0000000e
[ 4706.647418] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4706.656237] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4706.665009] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000cc88
[ 4706.672963] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000cc88
[ 4706.883622] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4706.890252] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4706.901321] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x0000000e
[ 4706.910110] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4706.918931] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4706.927666] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0000ccc8
[ 4706.935523] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0000ccc8
[ 4707.147511] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 4707.154081] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 4707.165046] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000c
[ 4707.173933] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x0000000e
[ 4707.182708] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
[ 4707.191444] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000c
Have a check the trace log.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
v4l2-ctl xxxxxx
cat /sys/kernel/debug/tracing/trace
Hi Shane, please help to check below log, thank you!
[14759.057941] WARNING: CPU: 4 PID: 9949 at …/drivers/media/v4l2-core/videobuf2-core.c:899 vb2_buffer_done+0x214/0x268
[14759.058031] —[ end trace 39948172e170a189 ]—
[14759.260567] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14759.267130] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[14759.277645] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000006
[14759.286514] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x00000004
[14759.286534] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[14759.286543] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[14759.286551] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00006000
[14759.286558] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00006000
[14759.304240] ------------[ cut here ]------------
[14759.304260] WARNING: CPU: 4 PID: 9949 at …/drivers/media/v4l2-core/videobuf2-core.c:899 vb2_buffer_done+0x214/0x268
[14759.304359] —[ end trace 39948172e170a18a ]—
[14759.508545] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14759.515086] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[14759.526336] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000006
[14759.535179] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x00000004
[14759.544104] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[14759.552921] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[14759.562905] ------------[ cut here ]------------
[14759.567577] WARNING: CPU: 3 PID: 9949 at …/drivers/media/v4l2-core/videobuf2-core.c:899 vb2_buffer_done+0x214/0x268
[14759.578315] —[ end trace 39948172e170a18b ]—
[14759.784574] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14759.791169] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[14759.802197] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000006
[14759.811055] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC1 = 0x00000004
[14759.819913] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[14759.828697] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x0000000e
[14759.838365] ------------[ cut here ]------------
[14759.843054] WARNING: CPU: 5 PID: 9949 at …/drivers/media/v4l2-core/videobuf2-core.c:899 vb2_buffer_done+0x214/0x268
[14759.854015] —[ end trace 39948172e170a18c ]—
tracer: nop
entries-in-buffer/entries-written: 4147/4147 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
 kworker/0:3-8636  [000] .... 14734.440007: rtos_queue_peek_from_isr_failed: tstamp:460829436001 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14734.440027: rtcpu_start: tstamp:460829437336
 kworker/0:3-8636  [000] .... 14734.440035: rtos_queue_send_from_isr_failed: tstamp:460829446285 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.440038: rtos_queue_send_from_isr_failed: tstamp:460829446395 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.440040: rtos_queue_send_from_isr_failed: tstamp:460829446504 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.440043: rtos_queue_send_from_isr_failed: tstamp:460829446610 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.440045: rtos_queue_send_from_isr_failed: tstamp:460829446715 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.440047: rtos_queue_send_from_isr_failed: tstamp:460829446823 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.440049: rtos_queue_send_from_isr_failed: tstamp:460829446928 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.440051: rtos_queue_send_from_isr_failed: tstamp:460829447033 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.440057: rtos_queue_send_failed: tstamp:460829447510 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.440059: rtos_queue_send_from_isr_failed: tstamp:460829449193 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.440061: rtos_queue_send_from_isr_failed: tstamp:460829449311 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.440063: rtos_queue_send_from_isr_failed: tstamp:460829449417 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.440065: rtos_queue_send_from_isr_failed: tstamp:460829449526 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.440067: rtos_queue_send_from_isr_failed: tstamp:460829449631 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.440069: rtos_queue_send_from_isr_failed: tstamp:460829449736 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.440070: rtos_queue_send_from_isr_failed: tstamp:460829449840 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.440073: rtos_queue_send_from_isr_failed: tstamp:460829449946 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.440075: rtos_queue_send_failed: tstamp:460829450862 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.440082: rtcpu_vinotify_event: tstamp:460829499761 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460829499378 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.440084: rtcpu_vinotify_event: tstamp:460829500399 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460829500014 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.440085: rtcpu_vinotify_event: tstamp:460829505011 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460829504648 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.440086: rtcpu_vinotify_event: tstamp:460829842741 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460829842255 data:0x00000001
 kworker/0:2-8609  [000] .... 14734.496110: rtcpu_vinotify_event: tstamp:460832165165 tag:CSIMUX_FRAME channel:0x03 frame:10 vi_tstamp:460832164722 data:0x000000a0
 kworker/0:3-8636  [000] .... 14734.552068: rtcpu_vinotify_event: tstamp:460834248545 tag:CSIMUX_FRAME channel:0x03 frame:12 vi_tstamp:460834248056 data:0x000000a0
 kworker/0:3-8636  [000] .... 14734.616056: rtos_queue_peek_from_isr_failed: tstamp:460834436511 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14734.667987: rtos_queue_send_from_isr_failed: tstamp:460836293729 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.667991: rtos_queue_send_from_isr_failed: tstamp:460836294025 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.667992: rtos_queue_send_from_isr_failed: tstamp:460836294299 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.667993: rtos_queue_send_from_isr_failed: tstamp:460836294574 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.667994: rtos_queue_send_from_isr_failed: tstamp:460836294841 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.667995: rtos_queue_send_from_isr_failed: tstamp:460836295114 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.667996: rtos_queue_send_from_isr_failed: tstamp:460836295383 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.667997: rtos_queue_send_from_isr_failed: tstamp:460836295651 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.667999: rtos_queue_send_failed: tstamp:460836297065 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668000: rtos_queue_send_from_isr_failed: tstamp:460836303421 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668001: rtos_queue_send_from_isr_failed: tstamp:460836303692 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.668002: rtos_queue_send_from_isr_failed: tstamp:460836303969 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.668003: rtos_queue_send_from_isr_failed: tstamp:460836304243 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.668004: rtos_queue_send_from_isr_failed: tstamp:460836304515 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.668005: rtos_queue_send_from_isr_failed: tstamp:460836304785 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.668006: rtos_queue_send_from_isr_failed: tstamp:460836305051 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.668007: rtos_queue_send_from_isr_failed: tstamp:460836305331 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.668008: rtos_queue_send_failed: tstamp:460836306435 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668009: rtos_queue_send_from_isr_failed: tstamp:460837653305 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668010: rtos_queue_send_from_isr_failed: tstamp:460837653450 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.668011: rtos_queue_send_from_isr_failed: tstamp:460837653589 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.668012: rtos_queue_send_from_isr_failed: tstamp:460837653733 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.668013: rtos_queue_send_from_isr_failed: tstamp:460837653876 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.668014: rtos_queue_send_from_isr_failed: tstamp:460837654035 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.668015: rtos_queue_send_from_isr_failed: tstamp:460837654193 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.668016: rtos_queue_send_from_isr_failed: tstamp:460837654352 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.668017: rtos_queue_send_failed: tstamp:460837654966 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668018: rtos_queue_send_from_isr_failed: tstamp:460837657418 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668019: rtos_queue_send_from_isr_failed: tstamp:460837657562 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.668020: rtos_queue_send_from_isr_failed: tstamp:460837657702 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.668021: rtos_queue_send_from_isr_failed: tstamp:460837657871 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.668021: rtos_queue_send_from_isr_failed: tstamp:460837658010 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.668022: rtos_queue_send_from_isr_failed: tstamp:460837658147 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.668023: rtos_queue_send_from_isr_failed: tstamp:460837658291 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.668024: rtos_queue_send_from_isr_failed: tstamp:460837658431 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.668025: rtos_queue_send_failed: tstamp:460837659835 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.668028: rtcpu_vinotify_event: tstamp:460837661361 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460837660208 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.668029: rtcpu_vinotify_event: tstamp:460837681806 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460837681394 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.724065: rtcpu_vinotify_event: tstamp:460837986251 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460837985845 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.724073: rtcpu_vinotify_event: tstamp:460838216907 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460838216508 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.724081: rtos_queue_peek_from_isr_failed: tstamp:460839436469 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14734.836065: rtcpu_vinotify_event: tstamp:460841540213 tag:CSIMUX_FRAME channel:0x03 frame:3 vi_tstamp:460841539727 data:0x000000a0
 kworker/0:3-8636  [000] .... 14734.898609: rtos_queue_peek_from_isr_failed: tstamp:460844436471 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14734.898616: rtos_queue_send_from_isr_failed: tstamp:460844540325 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.898619: rtos_queue_send_from_isr_failed: tstamp:460844540606 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.898621: rtos_queue_send_from_isr_failed: tstamp:460844540876 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.898624: rtos_queue_send_from_isr_failed: tstamp:460844541143 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.898626: rtos_queue_send_from_isr_failed: tstamp:460844541411 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.898628: rtos_queue_send_from_isr_failed: tstamp:460844541678 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.898630: rtos_queue_send_from_isr_failed: tstamp:460844541953 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.898632: rtos_queue_send_from_isr_failed: tstamp:460844542218 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.898636: rtos_queue_send_failed: tstamp:460844543620 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.898638: rtos_queue_send_from_isr_failed: tstamp:460844549702 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.898641: rtos_queue_send_from_isr_failed: tstamp:460844549976 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.898643: rtos_queue_send_from_isr_failed: tstamp:460844550253 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.898645: rtos_queue_send_from_isr_failed: tstamp:460844550519 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.898647: rtos_queue_send_from_isr_failed: tstamp:460844550786 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.898649: rtos_queue_send_from_isr_failed: tstamp:460844551070 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.898652: rtos_queue_send_from_isr_failed: tstamp:460844551340 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.898654: rtos_queue_send_from_isr_failed: tstamp:460844551607 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.898656: rtos_queue_send_failed: tstamp:460844552699 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.951964: rtos_queue_send_from_isr_failed: tstamp:460846167680 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.951972: rtos_queue_send_from_isr_failed: tstamp:460846167825 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.951975: rtos_queue_send_from_isr_failed: tstamp:460846167966 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.951977: rtos_queue_send_from_isr_failed: tstamp:460846168106 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.951980: rtos_queue_send_from_isr_failed: tstamp:460846168244 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.951982: rtos_queue_send_from_isr_failed: tstamp:460846168383 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.951984: rtos_queue_send_from_isr_failed: tstamp:460846168520 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.951987: rtos_queue_send_from_isr_failed: tstamp:460846168658 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.951990: rtos_queue_send_failed: tstamp:460846169279 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.951992: rtos_queue_send_from_isr_failed: tstamp:460846172271 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.951995: rtos_queue_send_from_isr_failed: tstamp:460846172428 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14734.951997: rtos_queue_send_from_isr_failed: tstamp:460846172568 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14734.952000: rtos_queue_send_from_isr_failed: tstamp:460846172715 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14734.952002: rtos_queue_send_from_isr_failed: tstamp:460846172852 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14734.952005: rtos_queue_send_from_isr_failed: tstamp:460846172991 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14734.952007: rtos_queue_send_from_isr_failed: tstamp:460846173128 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14734.952009: rtos_queue_send_from_isr_failed: tstamp:460846173266 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14734.952012: rtos_queue_send_failed: tstamp:460846174897 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14734.952016: rtcpu_vinotify_event: tstamp:460846176115 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460846174455 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.952018: rtcpu_vinotify_event: tstamp:460846246754 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460846246325 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.952020: rtcpu_vinotify_event: tstamp:460846259859 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460846259461 data:0x00000001
 kworker/0:3-8636  [000] .... 14734.952022: rtcpu_vinotify_event: tstamp:460846550248 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460846549845 data:0x00000001
 kworker/0:3-8636  [000] .... 14735.064119: rtos_queue_peek_from_isr_failed: tstamp:460849436516 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14735.120060: rtcpu_vinotify_event: tstamp:460850915220 tag:CSIMUX_FRAME channel:0x03 frame:12 vi_tstamp:460850914731 data:0x000000a0
 kworker/0:3-8636  [000] .... 14735.180504: rtcpu_vinotify_event: tstamp:460852998552 tag:CSIMUX_FRAME channel:0x03 frame:14 vi_tstamp:460852998065 data:0x000000a0
 kworker/0:3-8636  [000] .... 14735.180516: rtos_queue_send_from_isr_failed: tstamp:460853078357 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14735.180518: rtos_queue_send_from_isr_failed: tstamp:460853078648 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14735.180520: rtos_queue_send_from_isr_failed: tstamp:460853078919 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14735.180522: rtos_queue_send_from_isr_failed: tstamp:460853079222 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14735.180523: rtos_queue_send_from_isr_failed: tstamp:460853079491 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14735.180525: rtos_queue_send_from_isr_failed: tstamp:460853079763 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14735.180526: rtos_queue_send_from_isr_failed: tstamp:460853080035 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14735.180528: rtos_queue_send_from_isr_failed: tstamp:460853080306 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14735.180532: rtos_queue_send_failed: tstamp:460853081778 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14735.180533: rtos_queue_send_from_isr_failed: tstamp:460853088414 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14735.180535: rtos_queue_send_from_isr_failed: tstamp:460853088591 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14735.180537: rtos_queue_send_from_isr_failed: tstamp:460853088767 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14735.180538: rtos_queue_send_from_isr_failed: tstamp:460853088945 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14735.180539: rtos_queue_send_from_isr_failed: tstamp:460853089117 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14735.180541: rtos_queue_send_from_isr_failed: tstamp:460853089291 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14735.180542: rtos_queue_send_from_isr_failed: tstamp:460853089465 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14735.180544: rtos_queue_send_from_isr_failed: tstamp:460853089638 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14735.180545: rtos_queue_send_failed: tstamp:460853090405 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.235971: rtos_queue_peek_from_isr_failed: tstamp:460854436434 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14735.235978: rtos_queue_send_from_isr_failed: tstamp:460854707603 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.235979: rtos_queue_send_from_isr_failed: tstamp:460854707786 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.235980: rtos_queue_send_from_isr_failed: tstamp:460854707969 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.235981: rtos_queue_send_from_isr_failed: tstamp:460854708144 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.235984: rtos_queue_send_from_isr_failed: tstamp:460854708321 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.235986: rtos_queue_send_from_isr_failed: tstamp:460854708495 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.235987: rtos_queue_send_from_isr_failed: tstamp:460854708669 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.235988: rtos_queue_send_from_isr_failed: tstamp:460854708844 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.235990: rtos_queue_send_failed: tstamp:460854709610 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.235992: rtos_queue_send_from_isr_failed: tstamp:460854713452 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.235993: rtos_queue_send_from_isr_failed: tstamp:460854713629 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.235994: rtos_queue_send_from_isr_failed: tstamp:460854713805 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.235995: rtos_queue_send_from_isr_failed: tstamp:460854713981 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.235996: rtos_queue_send_from_isr_failed: tstamp:460854714155 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.235997: rtos_queue_send_from_isr_failed: tstamp:460854714329 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.235998: rtos_queue_send_from_isr_failed: tstamp:460854714501 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.235999: rtos_queue_send_from_isr_failed: tstamp:460854714687 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.236001: rtos_queue_send_failed: tstamp:460854716639 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.236003: rtcpu_vinotify_event: tstamp:460854719307 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460854718903 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.236004: rtcpu_vinotify_event: tstamp:460854816171 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460854815771 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.236005: rtcpu_vinotify_event: tstamp:460854844404 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460854844010 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.236006: rtcpu_vinotify_event: tstamp:460854885945 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460854885570 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.404125: rtos_queue_peek_from_isr_failed: tstamp:460859436593 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14735.460076: rtos_queue_send_from_isr_failed: tstamp:460861546321 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.460088: rtos_queue_send_from_isr_failed: tstamp:460861546614 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.460091: rtos_queue_send_from_isr_failed: tstamp:460861546892 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.460095: rtos_queue_send_from_isr_failed: tstamp:460861547163 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.460099: rtos_queue_send_from_isr_failed: tstamp:460861547438 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.460102: rtos_queue_send_from_isr_failed: tstamp:460861547710 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.460106: rtos_queue_send_from_isr_failed: tstamp:460861547982 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.460109: rtos_queue_send_from_isr_failed: tstamp:460861548249 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.460117: rtos_queue_send_failed: tstamp:460861549613 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.460121: rtos_queue_send_from_isr_failed: tstamp:460861555622 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.460125: rtos_queue_send_from_isr_failed: tstamp:460861555893 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.460129: rtos_queue_send_from_isr_failed: tstamp:460861556163 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.460133: rtos_queue_send_from_isr_failed: tstamp:460861556434 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.460136: rtos_queue_send_from_isr_failed: tstamp:460861556700 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.460140: rtos_queue_send_from_isr_failed: tstamp:460861556970 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.460144: rtos_queue_send_from_isr_failed: tstamp:460861557238 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.460147: rtos_queue_send_from_isr_failed: tstamp:460861557508 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.460151: rtos_queue_send_failed: tstamp:460861558593 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.516090: rtos_queue_send_from_isr_failed: tstamp:460863184278 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.516099: rtos_queue_send_from_isr_failed: tstamp:460863184562 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.516102: rtos_queue_send_from_isr_failed: tstamp:460863184837 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.516105: rtos_queue_send_from_isr_failed: tstamp:460863185105 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.516108: rtos_queue_send_from_isr_failed: tstamp:460863185375 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.516111: rtos_queue_send_from_isr_failed: tstamp:460863185650 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.516113: rtos_queue_send_from_isr_failed: tstamp:460863185918 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.516116: rtos_queue_send_from_isr_failed: tstamp:460863186229 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.516122: rtos_queue_send_failed: tstamp:460863187415 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.516125: rtos_queue_send_from_isr_failed: tstamp:460863191630 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.516128: rtos_queue_send_from_isr_failed: tstamp:460863191901 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.516131: rtos_queue_send_from_isr_failed: tstamp:460863192173 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.516133: rtos_queue_send_from_isr_failed: tstamp:460863192448 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.516136: rtos_queue_send_from_isr_failed: tstamp:460863192728 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.516139: rtos_queue_send_from_isr_failed: tstamp:460863192999 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.516142: rtos_queue_send_from_isr_failed: tstamp:460863193274 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.516145: rtos_queue_send_from_isr_failed: tstamp:460863193547 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.516148: rtos_queue_send_failed: tstamp:460863196784 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.516155: rtcpu_vinotify_event: tstamp:460863199533 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460863196791 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.516157: rtcpu_vinotify_event: tstamp:460863216347 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460863215882 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.516160: rtcpu_vinotify_event: tstamp:460863216943 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460863216520 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.516162: rtcpu_vinotify_event: tstamp:460863485647 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460863485221 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.572092: rtos_queue_peek_from_isr_failed: tstamp:460864436434 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14735.628109: rtcpu_vinotify_event: tstamp:460867581849 tag:CSIMUX_FRAME channel:0x03 frame:12 vi_tstamp:460867581405 data:0x000000a0
 kworker/0:2-8609  [000] .... 14735.686711: rtos_queue_peek_from_isr_failed: tstamp:460869436509 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14735.740001: rtos_queue_send_from_isr_failed: tstamp:460870072630 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.740007: rtos_queue_send_from_isr_failed: tstamp:460870072922 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.740008: rtos_queue_send_from_isr_failed: tstamp:460870073205 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.740010: rtos_queue_send_from_isr_failed: tstamp:460870073478 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.740011: rtos_queue_send_from_isr_failed: tstamp:460870073747 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.740012: rtos_queue_send_from_isr_failed: tstamp:460870074015 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.740013: rtos_queue_send_from_isr_failed: tstamp:460870074290 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.740015: rtos_queue_send_from_isr_failed: tstamp:460870074557 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.740018: rtos_queue_send_failed: tstamp:460870075941 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.740019: rtos_queue_send_from_isr_failed: tstamp:460870083202 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.740020: rtos_queue_send_from_isr_failed: tstamp:460870083541 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.740021: rtos_queue_send_from_isr_failed: tstamp:460870083812 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.740023: rtos_queue_send_from_isr_failed: tstamp:460870084080 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.740024: rtos_queue_send_from_isr_failed: tstamp:460870084350 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.740025: rtos_queue_send_from_isr_failed: tstamp:460870084630 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.740026: rtos_queue_send_from_isr_failed: tstamp:460870084897 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.740028: rtos_queue_send_from_isr_failed: tstamp:460870085169 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.740029: rtos_queue_send_failed: tstamp:460870086273 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.796131: rtos_queue_send_from_isr_failed: tstamp:460871706211 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.796140: rtos_queue_send_from_isr_failed: tstamp:460871706377 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.796144: rtos_queue_send_from_isr_failed: tstamp:460871706517 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.796147: rtos_queue_send_from_isr_failed: tstamp:460871706657 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.796149: rtos_queue_send_from_isr_failed: tstamp:460871706793 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.796152: rtos_queue_send_from_isr_failed: tstamp:460871706931 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.796155: rtos_queue_send_from_isr_failed: tstamp:460871707068 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.796157: rtos_queue_send_from_isr_failed: tstamp:460871707204 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.796164: rtos_queue_send_failed: tstamp:460871707803 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.796167: rtos_queue_send_from_isr_failed: tstamp:460871710704 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.796169: rtos_queue_send_from_isr_failed: tstamp:460871710861 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14735.796172: rtos_queue_send_from_isr_failed: tstamp:460871711001 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14735.796175: rtos_queue_send_from_isr_failed: tstamp:460871711141 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14735.796178: rtos_queue_send_from_isr_failed: tstamp:460871711280 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14735.796180: rtos_queue_send_from_isr_failed: tstamp:460871711418 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14735.796183: rtos_queue_send_from_isr_failed: tstamp:460871711557 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14735.796186: rtos_queue_send_from_isr_failed: tstamp:460871711696 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14735.796188: rtos_queue_send_failed: tstamp:460871713095 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14735.796196: rtcpu_vinotify_event: tstamp:460871716519 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460871716133 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.796197: rtcpu_vinotify_event: tstamp:460871749864 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460871749466 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.796200: rtcpu_vinotify_event: tstamp:460871825879 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460871825503 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.796201: rtcpu_vinotify_event: tstamp:460872591920 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460872591524 data:0x00000001
 kworker/0:2-8609  [000] .... 14735.852128: rtos_queue_peek_from_isr_failed: tstamp:460874436497 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14736.024055: rtos_queue_send_from_isr_failed: tstamp:460878544727 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024065: rtos_queue_send_from_isr_failed: tstamp:460878545024 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.024067: rtos_queue_send_from_isr_failed: tstamp:460878545301 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.024069: rtos_queue_send_from_isr_failed: tstamp:460878545649 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.024071: rtos_queue_send_from_isr_failed: tstamp:460878545917 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.024073: rtos_queue_send_from_isr_failed: tstamp:460878546218 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.024075: rtos_queue_send_from_isr_failed: tstamp:460878546485 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.024077: rtos_queue_send_from_isr_failed: tstamp:460878546760 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.024081: rtos_queue_send_failed: tstamp:460878548231 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024082: rtos_queue_send_from_isr_failed: tstamp:460878553616 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024084: rtos_queue_send_from_isr_failed: tstamp:460878553883 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.024086: rtos_queue_send_from_isr_failed: tstamp:460878554156 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.024088: rtos_queue_send_from_isr_failed: tstamp:460878554425 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.024090: rtos_queue_send_from_isr_failed: tstamp:460878554689 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.024091: rtos_queue_send_from_isr_failed: tstamp:460878554956 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.024093: rtos_queue_send_from_isr_failed: tstamp:460878555225 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.024095: rtos_queue_send_from_isr_failed: tstamp:460878555492 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.024097: rtos_queue_send_failed: tstamp:460878556632 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024099: rtos_queue_peek_from_isr_failed: tstamp:460879436517 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14736.024100: rtos_queue_send_from_isr_failed: tstamp:460880180661 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024102: rtos_queue_send_from_isr_failed: tstamp:460880180846 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.024104: rtos_queue_send_from_isr_failed: tstamp:460880181031 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.024106: rtos_queue_send_from_isr_failed: tstamp:460880181212 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.024108: rtos_queue_send_from_isr_failed: tstamp:460880181387 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.024110: rtos_queue_send_from_isr_failed: tstamp:460880181561 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.024112: rtos_queue_send_from_isr_failed: tstamp:460880181734 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.024113: rtos_queue_send_from_isr_failed: tstamp:460880181911 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.024115: rtos_queue_send_failed: tstamp:460880182685 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024117: rtos_queue_send_from_isr_failed: tstamp:460880189067 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024119: rtos_queue_send_from_isr_failed: tstamp:460880189242 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.024121: rtos_queue_send_from_isr_failed: tstamp:460880189421 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.024123: rtos_queue_send_from_isr_failed: tstamp:460880189596 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.024125: rtos_queue_send_from_isr_failed: tstamp:460880189771 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.024127: rtos_queue_send_from_isr_failed: tstamp:460880189950 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.024132: rtos_queue_send_from_isr_failed: tstamp:460880190124 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.024134: rtos_queue_send_from_isr_failed: tstamp:460880190335 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.024135: rtos_queue_send_failed: tstamp:460880192266 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.024140: rtcpu_vinotify_event: tstamp:460880206967 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460880206414 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.080131: rtcpu_vinotify_event: tstamp:460880383518 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460880383088 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.080138: rtcpu_vinotify_event: tstamp:460880516268 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460880515785 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.080142: rtcpu_vinotify_event: tstamp:460881967033 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460881966528 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.192109: rtos_queue_peek_from_isr_failed: tstamp:460884436524 queue:0x0b4b4500
 kworker/0:2-8609  [000] .... 14736.248084: rtos_queue_send_from_isr_failed: tstamp:460887072801 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.248093: rtos_queue_send_from_isr_failed: tstamp:460887073139 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.248095: rtos_queue_send_from_isr_failed: tstamp:460887073416 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.248098: rtos_queue_send_from_isr_failed: tstamp:460887073681 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.248100: rtos_queue_send_from_isr_failed: tstamp:460887073952 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.248103: rtos_queue_send_from_isr_failed: tstamp:460887074221 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.248105: rtos_queue_send_from_isr_failed: tstamp:460887074489 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.248107: rtos_queue_send_from_isr_failed: tstamp:460887074762 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.248112: rtos_queue_send_failed: tstamp:460887076259 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.248114: rtos_queue_send_from_isr_failed: tstamp:460887084352 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.248116: rtos_queue_send_from_isr_failed: tstamp:460887084688 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.248119: rtos_queue_send_from_isr_failed: tstamp:460887084973 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.248121: rtos_queue_send_from_isr_failed: tstamp:460887085241 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.248123: rtos_queue_send_from_isr_failed: tstamp:460887085510 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.248125: rtos_queue_send_from_isr_failed: tstamp:460887085781 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.248127: rtos_queue_send_from_isr_failed: tstamp:460887086053 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.248129: rtos_queue_send_from_isr_failed: tstamp:460887086324 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.248131: rtos_queue_send_failed: tstamp:460887087368 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.304039: rtos_queue_send_from_isr_failed: tstamp:460888701477 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.304047: rtos_queue_send_from_isr_failed: tstamp:460888701599 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.304050: rtos_queue_send_from_isr_failed: tstamp:460888701706 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.304053: rtos_queue_send_from_isr_failed: tstamp:460888701812 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.304054: rtos_queue_send_from_isr_failed: tstamp:460888701921 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.304057: rtos_queue_send_from_isr_failed: tstamp:460888702026 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.304058: rtos_queue_send_from_isr_failed: tstamp:460888702130 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.304061: rtos_queue_send_from_isr_failed: tstamp:460888702246 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.304064: rtos_queue_send_failed: tstamp:460888702756 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.304066: rtos_queue_send_from_isr_failed: tstamp:460888704770 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.304068: rtos_queue_send_from_isr_failed: tstamp:460888704885 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.304070: rtos_queue_send_from_isr_failed: tstamp:460888704991 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.304072: rtos_queue_send_from_isr_failed: tstamp:460888705100 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.304074: rtos_queue_send_from_isr_failed: tstamp:460888705205 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.304076: rtos_queue_send_from_isr_failed: tstamp:460888705319 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.304078: rtos_queue_send_from_isr_failed: tstamp:460888705424 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.304080: rtos_queue_send_from_isr_failed: tstamp:460888705531 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.304082: rtos_queue_send_failed: tstamp:460888706471 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.304089: rtcpu_vinotify_event: tstamp:460888784580 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460888784196 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.304090: rtcpu_vinotify_event: tstamp:460888911246 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460888910870 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.304092: rtcpu_vinotify_event: tstamp:460889023218 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460889022733 data:0x00000001
 kworker/0:3-8636  [000] .... 14736.360198: rtcpu_vinotify_event: tstamp:460889258574 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460889258198 data:0x00000001
 kworker/0:3-8636  [000] .... 14736.360218: rtos_queue_peek_from_isr_failed: tstamp:460889436420 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14736.531920: rtos_queue_peek_from_isr_failed: tstamp:460894436544 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14736.531935: rtos_queue_send_from_isr_failed: tstamp:460895576855 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.531937: rtos_queue_send_from_isr_failed: tstamp:460895577157 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14736.531940: rtos_queue_send_from_isr_failed: tstamp:460895577432 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14736.531943: rtos_queue_send_from_isr_failed: tstamp:460895577701 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14736.531945: rtos_queue_send_from_isr_failed: tstamp:460895577965 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14736.531947: rtos_queue_send_from_isr_failed: tstamp:460895578230 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14736.531948: rtos_queue_send_from_isr_failed: tstamp:460895578498 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14736.531950: rtos_queue_send_from_isr_failed: tstamp:460895578767 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14736.531954: rtos_queue_send_failed: tstamp:460895580169 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.531955: rtos_queue_send_from_isr_failed: tstamp:460895587686 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.531957: rtos_queue_send_from_isr_failed: tstamp:460895588040 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14736.531958: rtos_queue_send_from_isr_failed: tstamp:460895588306 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14736.531960: rtos_queue_send_from_isr_failed: tstamp:460895588573 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14736.531962: rtos_queue_send_from_isr_failed: tstamp:460895588838 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14736.531963: rtos_queue_send_from_isr_failed: tstamp:460895589104 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14736.531965: rtos_queue_send_from_isr_failed: tstamp:460895589368 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14736.531966: rtos_queue_send_from_isr_failed: tstamp:460895589635 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14736.532008: rtos_queue_send_failed: tstamp:460895590771 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.588093: rtos_queue_send_from_isr_failed: tstamp:460897213366 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.588101: rtos_queue_send_from_isr_failed: tstamp:460897213517 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.588104: rtos_queue_send_from_isr_failed: tstamp:460897213655 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.588107: rtos_queue_send_from_isr_failed: tstamp:460897213799 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.588110: rtos_queue_send_from_isr_failed: tstamp:460897213937 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.588113: rtos_queue_send_from_isr_failed: tstamp:460897214077 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.588116: rtos_queue_send_from_isr_failed: tstamp:460897214216 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.588118: rtos_queue_send_from_isr_failed: tstamp:460897214356 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.588123: rtos_queue_send_failed: tstamp:460897214970 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.588125: rtos_queue_send_from_isr_failed: tstamp:460897217133 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.588128: rtos_queue_send_from_isr_failed: tstamp:460897217272 queue:0x0b4aad68
 kworker/0:2-8609  [000] .... 14736.588131: rtos_queue_send_from_isr_failed: tstamp:460897217411 queue:0x0b4ac998
 kworker/0:2-8609  [000] .... 14736.588134: rtos_queue_send_from_isr_failed: tstamp:460897217551 queue:0x0b4ae518
 kworker/0:2-8609  [000] .... 14736.588137: rtos_queue_send_from_isr_failed: tstamp:460897217688 queue:0x0b4af2d8
 kworker/0:2-8609  [000] .... 14736.588140: rtos_queue_send_from_isr_failed: tstamp:460897217829 queue:0x0b4b0098
 kworker/0:2-8609  [000] .... 14736.588142: rtos_queue_send_from_isr_failed: tstamp:460897217971 queue:0x0b4b0e58
 kworker/0:2-8609  [000] .... 14736.588145: rtos_queue_send_from_isr_failed: tstamp:460897218108 queue:0x0b4b1c18
 kworker/0:2-8609  [000] .... 14736.588148: rtos_queue_send_failed: tstamp:460897219501 queue:0x0b4a7258
 kworker/0:2-8609  [000] .... 14736.588154: rtcpu_vinotify_event: tstamp:460897237028 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:460897236624 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.588155: rtcpu_vinotify_event: tstamp:460897454046 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460897453644 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.588156: rtcpu_vinotify_event: tstamp:460897591318 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460897590898 data:0x00000001
 kworker/0:2-8609  [000] .... 14736.588157: rtcpu_vinotify_event: tstamp:460897754326 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460897753928 data:0x00000001
 kworker/0:3-8636  [000] .... 14736.644123: rtos_queue_peek_from_isr_failed: tstamp:460899436547 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14736.812134: rtcpu_vinotify_event: tstamp:460904040178 tag:CSIMUX_FRAME channel:0x03 frame:12 vi_tstamp:460904039755 data:0x000000a0
 kworker/0:3-8636  [000] .... 14736.812159: rtos_queue_send_from_isr_failed: tstamp:460904069447 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.812164: rtos_queue_send_from_isr_failed: tstamp:460904069632 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14736.812167: rtos_queue_send_from_isr_failed: tstamp:460904069810 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14736.812169: rtos_queue_send_from_isr_failed: tstamp:460904069985 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14736.812171: rtos_queue_send_from_isr_failed: tstamp:460904070160 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14736.812173: rtos_queue_send_from_isr_failed: tstamp:460904070366 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14736.812175: rtos_queue_send_from_isr_failed: tstamp:460904070571 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14736.812177: rtos_queue_send_from_isr_failed: tstamp:460904070755 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14736.812185: rtos_queue_send_failed: tstamp:460904071715 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.812187: rtos_queue_send_from_isr_failed: tstamp:460904075470 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.812188: rtos_queue_send_from_isr_failed: tstamp:460904075688 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14736.812190: rtos_queue_send_from_isr_failed: tstamp:460904075879 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14736.812191: rtos_queue_send_from_isr_failed: tstamp:460904076055 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14736.812193: rtos_queue_send_from_isr_failed: tstamp:460904076235 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14736.812195: rtos_queue_send_from_isr_failed: tstamp:460904076415 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14736.812197: rtos_queue_send_from_isr_failed: tstamp:460904076602 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14736.812200: rtos_queue_send_from_isr_failed: tstamp:460904076780 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14736.812202: rtos_queue_send_failed: tstamp:460904077639 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.812208: rtos_queue_peek_from_isr_failed: tstamp:460904436460 queue:0x0b4b4500
 kworker/0:3-8636  [000] .... 14736.868058: rtos_queue_send_from_isr_failed: tstamp:460905703061 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.868068: rtos_queue_send_from_isr_failed: tstamp:460905703352 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14736.868070: rtos_queue_send_from_isr_failed: tstamp:460905703627 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14736.868072: rtos_queue_send_from_isr_failed: tstamp:460905703901 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14736.868074: rtos_queue_send_from_isr_failed: tstamp:460905704183 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14736.868077: rtos_queue_send_from_isr_failed: tstamp:460905704462 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14736.868079: rtos_queue_send_from_isr_failed: tstamp:460905704733 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14736.868081: rtos_queue_send_from_isr_failed: tstamp:460905705000 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14736.868085: rtos_queue_send_failed: tstamp:460905706243 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.868087: rtos_queue_send_from_isr_failed: tstamp:460905712588 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.868089: rtos_queue_send_from_isr_failed: tstamp:460905712929 queue:0x0b4aad68
 kworker/0:3-8636  [000] .... 14736.868091: rtos_queue_send_from_isr_failed: tstamp:460905713201 queue:0x0b4ac998
 kworker/0:3-8636  [000] .... 14736.868093: rtos_queue_send_from_isr_failed: tstamp:460905713474 queue:0x0b4ae518
 kworker/0:3-8636  [000] .... 14736.868095: rtos_queue_send_from_isr_failed: tstamp:460905713748 queue:0x0b4af2d8
 kworker/0:3-8636  [000] .... 14736.868098: rtos_queue_send_from_isr_failed: tstamp:460905714023 queue:0x0b4b0098
 kworker/0:3-8636  [000] .... 14736.868100: rtos_queue_send_from_isr_failed: tstamp:460905714294 queue:0x0b4b0e58
 kworker/0:3-8636  [000] .... 14736.868102: rtos_queue_send_from_isr_failed: tstamp:460905714565 queue:0x0b4b1c18
 kworker/0:3-8636  [000] .... 14736.868104: rtos_queue_send_failed: tstamp:460905717993 queue:0x0b4a7258
 kworker/0:3-8636  [000] .... 14736.868108: rtcpu_vinotify_event: tstamp:460905720425 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:460905717537 data:0x00000001
 kworker/0:3-8636  [000] .... 14736.868110: rtcpu_vinotify_event: tstamp:460905759610 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:460905759204 data:0x00000001
 kworker/0:3-8636  [000] .... 14736.868111: rtcpu_vinotify_event: tstamp:460905868978 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:460905868574 data:0x00000001
 kworker/0:3-8636  [000] .... 14736.868113: rtcpu_vinotify_event: tstamp:460905873135 tag:CSIMUX_STREAM channel:0xff frame:0
Did see any FS/FE package.
Please check the trace log for the single video case to confirm the FS/FE package are showing.
Hi Shane, I checked signal, The LP->HS is not detected, the HS signal is not terminated.
Hi Shane, what is min LP11 period between two long packets, it seems that 50ns cannot trig the second Long packet to be detected.
Hi Shane, I can fix the issue by adjust the power; doese TX2 CSI support async virtual channel mode, that is assume that VC1 at line 2, but VC2 at line 40, VC3 at line 100, VC4 at line 300 because analog camera don’t have sync funtion, not like serdes that it can make all cameras sync. below is log information
root@bob-desktop:/home/bob# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 1005/1005 #P:4
_-----=> irqs-off
||| / delay
 kworker/3:0-30    [003] ....  6261.323910: rtos_queue_peek_from_isr_failed: tstamp:196050238106 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6261.323921: rtcpu_start: tstamp:196050239257
 kworker/3:0-30    [003] ....  6261.323924: rtos_queue_send_from_isr_failed: tstamp:196050247975 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.323927: rtos_queue_send_from_isr_failed: tstamp:196050248083 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.323930: rtos_queue_send_from_isr_failed: tstamp:196050248189 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.323932: rtos_queue_send_from_isr_failed: tstamp:196050248297 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.323934: rtos_queue_send_from_isr_failed: tstamp:196050248402 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.323936: rtos_queue_send_from_isr_failed: tstamp:196050248507 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.323938: rtos_queue_send_from_isr_failed: tstamp:196050248614 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.323940: rtos_queue_send_from_isr_failed: tstamp:196050248718 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.323944: rtos_queue_send_failed: tstamp:196050249249 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.323946: rtos_queue_send_from_isr_failed: tstamp:196050251409 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.323949: rtos_queue_send_from_isr_failed: tstamp:196050251514 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.323951: rtos_queue_send_from_isr_failed: tstamp:196050251619 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.323953: rtos_queue_send_from_isr_failed: tstamp:196050251728 queue:0x0b4ae518
 kworker/3:0-30    [003] .n..  6261.323958: rtos_queue_send_from_isr_failed: tstamp:196050251833 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.324002: rtos_queue_send_from_isr_failed: tstamp:196050251938 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.324005: rtos_queue_send_from_isr_failed: tstamp:196050252043 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.324007: rtos_queue_send_from_isr_failed: tstamp:196050252148 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.324010: rtos_queue_send_failed: tstamp:196050253049 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.324014: rtcpu_vinotify_event: tstamp:196050586013 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:196050585413 data:0x00000001
 kworker/3:0-30    [003] ....  6261.324016: rtcpu_vinotify_event: tstamp:196050586247 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196050585763 data:0x00000001
 kworker/3:0-30    [003] ....  6261.324018: rtcpu_vinotify_event: tstamp:196050839407 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196050839035 data:0x00000001
 kworker/3:0-30    [003] ....  6261.324021: rtcpu_vinotify_event: tstamp:196050942309 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196050941904 data:0x00000001
 kworker/3:0-30    [003] ....  6261.435944: rtcpu_vinotify_event: tstamp:196054286117 tag:CSIMUX_FRAME channel:0x02 frame:6 vi_tstamp:196054285700 data:0x000000a0
 kworker/3:0-30    [003] ....  6261.435950: rtcpu_vinotify_event: tstamp:196054291085 tag:CSIMUX_FRAME channel:0x01 frame:4 vi_tstamp:196054290674 data:0x000000a0
 kworker/3:0-30    [003] ....  6261.491924: rtos_queue_peek_from_isr_failed: tstamp:196055238519 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6261.551839: rtcpu_vinotify_event: tstamp:196057411125 tag:CSIMUX_FRAME channel:0x02 frame:7 vi_tstamp:196057410707 data:0x000000a0
 kworker/3:0-30    [003] ....  6261.551843: rtos_queue_send_from_isr_failed: tstamp:196057674690 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.551844: rtos_queue_send_from_isr_failed: tstamp:196057674869 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.551844: rtos_queue_send_from_isr_failed: tstamp:196057675079 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.551845: rtos_queue_send_from_isr_failed: tstamp:196057675255 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.551846: rtos_queue_send_from_isr_failed: tstamp:196057675432 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.551847: rtos_queue_send_from_isr_failed: tstamp:196057675606 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.551848: rtos_queue_send_from_isr_failed: tstamp:196057675779 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.551849: rtos_queue_send_from_isr_failed: tstamp:196057675953 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.551850: rtos_queue_send_failed: tstamp:196057676840 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.551851: rtos_queue_send_from_isr_failed: tstamp:196057681294 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.551852: rtos_queue_send_from_isr_failed: tstamp:196057681496 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.551853: rtos_queue_send_from_isr_failed: tstamp:196057681670 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.551854: rtos_queue_send_from_isr_failed: tstamp:196057681846 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.551854: rtos_queue_send_from_isr_failed: tstamp:196057682020 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.551855: rtos_queue_send_from_isr_failed: tstamp:196057682199 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.551856: rtos_queue_send_from_isr_failed: tstamp:196057682376 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.551857: rtos_queue_send_from_isr_failed: tstamp:196057682548 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.551858: rtos_queue_send_failed: tstamp:196057683248 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.607876: rtos_queue_send_from_isr_failed: tstamp:196059286114 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.607881: rtos_queue_send_from_isr_failed: tstamp:196059286222 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.607883: rtos_queue_send_from_isr_failed: tstamp:196059286328 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.607886: rtos_queue_send_from_isr_failed: tstamp:196059286436 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.607888: rtos_queue_send_from_isr_failed: tstamp:196059286541 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.607890: rtos_queue_send_from_isr_failed: tstamp:196059286646 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.607892: rtos_queue_send_from_isr_failed: tstamp:196059286751 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.607894: rtos_queue_send_from_isr_failed: tstamp:196059286856 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.607897: rtos_queue_send_failed: tstamp:196059287303 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.607899: rtos_queue_send_from_isr_failed: tstamp:196059298575 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.607901: rtos_queue_send_from_isr_failed: tstamp:196059298682 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.607904: rtos_queue_send_from_isr_failed: tstamp:196059298788 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.607906: rtos_queue_send_from_isr_failed: tstamp:196059298894 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.607908: rtos_queue_send_from_isr_failed: tstamp:196059298999 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.607910: rtos_queue_send_from_isr_failed: tstamp:196059299103 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.607912: rtos_queue_send_from_isr_failed: tstamp:196059299207 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.607914: rtos_queue_send_from_isr_failed: tstamp:196059299313 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.607917: rtos_queue_send_failed: tstamp:196059300221 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.663925: rtos_queue_peek_from_isr_failed: tstamp:196060238490 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6261.775960: rtos_queue_peek_from_isr_failed: tstamp:196065238728 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6261.831933: rtos_queue_send_from_isr_failed: tstamp:196066207559 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.831954: rtos_queue_send_from_isr_failed: tstamp:196066208215 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.831960: rtos_queue_send_from_isr_failed: tstamp:196066208856 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.831965: rtos_queue_send_from_isr_failed: tstamp:196066209497 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.831970: rtos_queue_send_from_isr_failed: tstamp:196066210133 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.831976: rtos_queue_send_from_isr_failed: tstamp:196066210771 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.831983: rtos_queue_send_from_isr_failed: tstamp:196066211418 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.831986: rtos_queue_send_from_isr_failed: tstamp:196066212055 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.831997: rtos_queue_send_failed: tstamp:196066214651 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.832002: rtos_queue_send_from_isr_failed: tstamp:196066223154 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.832007: rtos_queue_send_from_isr_failed: tstamp:196066223792 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.832011: rtos_queue_send_from_isr_failed: tstamp:196066224430 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.832014: rtos_queue_send_from_isr_failed: tstamp:196066225073 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.832017: rtos_queue_send_from_isr_failed: tstamp:196066225714 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.832022: rtos_queue_send_from_isr_failed: tstamp:196066226353 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.832027: rtos_queue_send_from_isr_failed: tstamp:196066226994 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.832030: rtos_queue_send_from_isr_failed: tstamp:196066227646 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.832036: rtos_queue_send_failed: tstamp:196066230237 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.888011: rtos_queue_send_from_isr_failed: tstamp:196067352428 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.888019: rtos_queue_send_from_isr_failed: tstamp:196067353075 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.888026: rtos_queue_send_from_isr_failed: tstamp:196067353719 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.888032: rtos_queue_send_from_isr_failed: tstamp:196067354368 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.888038: rtos_queue_send_from_isr_failed: tstamp:196067355015 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.888042: rtos_queue_send_from_isr_failed: tstamp:196067355662 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.888048: rtos_queue_send_from_isr_failed: tstamp:196067356303 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.888055: rtos_queue_send_from_isr_failed: tstamp:196067356953 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.888064: rtos_queue_send_failed: tstamp:196067359760 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.888070: rtos_queue_send_from_isr_failed: tstamp:196067367317 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.888076: rtos_queue_send_from_isr_failed: tstamp:196067368238 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6261.888082: rtos_queue_send_from_isr_failed: tstamp:196067368886 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6261.888089: rtos_queue_send_from_isr_failed: tstamp:196067369533 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6261.888095: rtos_queue_send_from_isr_failed: tstamp:196067370179 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6261.888101: rtos_queue_send_from_isr_failed: tstamp:196067370839 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6261.888107: rtos_queue_send_from_isr_failed: tstamp:196067371484 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6261.888114: rtos_queue_send_from_isr_failed: tstamp:196067372146 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6261.888121: rtos_queue_send_failed: tstamp:196067381165 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6261.888136: rtcpu_vinotify_event: tstamp:196067387002 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196067384699 data:0x00000001
 kworker/3:0-30    [003] ....  6261.888143: rtcpu_vinotify_event: tstamp:196067461750 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196067461324 data:0x00000001
 kworker/3:0-30    [003] ....  6261.888147: rtcpu_vinotify_event: tstamp:196067471821 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:196067471406 data:0x00000001
 kworker/3:0-30    [003] ....  6261.888151: rtcpu_vinotify_event: tstamp:196067472313 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196067471850 data:0x00000001
 kworker/3:0-30    [003] ....  6261.944012: rtos_queue_peek_from_isr_failed: tstamp:196070238951 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.059900: rtos_queue_send_from_isr_failed: tstamp:196074182718 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.059905: rtos_queue_send_from_isr_failed: tstamp:196074183370 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.059907: rtos_queue_send_from_isr_failed: tstamp:196074184022 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.059909: rtos_queue_send_from_isr_failed: tstamp:196074184707 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.059911: rtos_queue_send_from_isr_failed: tstamp:196074185350 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.059912: rtos_queue_send_from_isr_failed: tstamp:196074185992 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.059914: rtos_queue_send_from_isr_failed: tstamp:196074186639 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.059916: rtos_queue_send_from_isr_failed: tstamp:196074187281 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.059918: rtos_queue_send_failed: tstamp:196074190335 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.059920: rtos_queue_send_from_isr_failed: tstamp:196074197395 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.059922: rtos_queue_send_from_isr_failed: tstamp:196074198039 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.059923: rtos_queue_send_from_isr_failed: tstamp:196074198682 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.059925: rtos_queue_send_from_isr_failed: tstamp:196074199326 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.059927: rtos_queue_send_from_isr_failed: tstamp:196074199965 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.059929: rtos_queue_send_from_isr_failed: tstamp:196074200610 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.059931: rtos_queue_send_from_isr_failed: tstamp:196074201267 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.059933: rtos_queue_send_from_isr_failed: tstamp:196074201909 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.059935: rtos_queue_send_failed: tstamp:196074204580 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.115930: rtos_queue_peek_from_isr_failed: tstamp:196075238491 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.115956: rtos_queue_send_from_isr_failed: tstamp:196075824332 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.115963: rtos_queue_send_from_isr_failed: tstamp:196075824975 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.115969: rtos_queue_send_from_isr_failed: tstamp:196075825636 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.115975: rtos_queue_send_from_isr_failed: tstamp:196075826286 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.115982: rtos_queue_send_from_isr_failed: tstamp:196075826939 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.115988: rtos_queue_send_from_isr_failed: tstamp:196075827585 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.115994: rtos_queue_send_from_isr_failed: tstamp:196075828245 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.115998: rtos_queue_send_from_isr_failed: tstamp:196075828891 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.116007: rtos_queue_send_failed: tstamp:196075831501 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.116013: rtos_queue_send_from_isr_failed: tstamp:196075839241 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.116020: rtos_queue_send_from_isr_failed: tstamp:196075839888 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.116026: rtos_queue_send_from_isr_failed: tstamp:196075840535 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.116032: rtos_queue_send_from_isr_failed: tstamp:196075841182 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.116049: rtos_queue_send_from_isr_failed: tstamp:196075841828 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.116056: rtos_queue_send_from_isr_failed: tstamp:196075842472 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.116062: rtos_queue_send_from_isr_failed: tstamp:196075843118 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.116068: rtos_queue_send_from_isr_failed: tstamp:196075843800 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.116077: rtos_queue_send_failed: tstamp:196075852584 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.283974: rtos_queue_peek_from_isr_failed: tstamp:196080238954 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.339934: rtos_queue_send_from_isr_failed: tstamp:196082679370 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.339947: rtos_queue_send_from_isr_failed: tstamp:196082679546 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.339953: rtos_queue_send_from_isr_failed: tstamp:196082679721 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.339959: rtos_queue_send_from_isr_failed: tstamp:196082679896 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.339965: rtos_queue_send_from_isr_failed: tstamp:196082680069 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.339969: rtos_queue_send_from_isr_failed: tstamp:196082680241 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.339976: rtos_queue_send_from_isr_failed: tstamp:196082680414 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.339979: rtos_queue_send_from_isr_failed: tstamp:196082680585 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.339991: rtos_queue_send_failed: tstamp:196082681434 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.339997: rtos_queue_send_from_isr_failed: tstamp:196082687645 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.340004: rtos_queue_send_from_isr_failed: tstamp:196082687820 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.340010: rtos_queue_send_from_isr_failed: tstamp:196082688024 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.340016: rtos_queue_send_from_isr_failed: tstamp:196082688199 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.340023: rtos_queue_send_from_isr_failed: tstamp:196082688387 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.340029: rtos_queue_send_from_isr_failed: tstamp:196082688561 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.340036: rtos_queue_send_from_isr_failed: tstamp:196082688733 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.340042: rtos_queue_send_from_isr_failed: tstamp:196082688907 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.340048: rtos_queue_send_failed: tstamp:196082689598 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.395886: rtos_queue_send_from_isr_failed: tstamp:196083814186 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.395890: rtos_queue_send_from_isr_failed: tstamp:196083814389 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.395892: rtos_queue_send_from_isr_failed: tstamp:196083814565 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.395893: rtos_queue_send_from_isr_failed: tstamp:196083814741 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.395895: rtos_queue_send_from_isr_failed: tstamp:196083814915 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.395897: rtos_queue_send_from_isr_failed: tstamp:196083815087 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.395899: rtos_queue_send_from_isr_failed: tstamp:196083815261 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.395901: rtos_queue_send_from_isr_failed: tstamp:196083815435 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.395903: rtos_queue_send_failed: tstamp:196083816175 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.395905: rtos_queue_send_from_isr_failed: tstamp:196083819147 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.395906: rtos_queue_send_from_isr_failed: tstamp:196083819351 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.395908: rtos_queue_send_from_isr_failed: tstamp:196083819532 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.395910: rtos_queue_send_from_isr_failed: tstamp:196083819707 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.395912: rtos_queue_send_from_isr_failed: tstamp:196083819881 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.395914: rtos_queue_send_from_isr_failed: tstamp:196083820055 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.395915: rtos_queue_send_from_isr_failed: tstamp:196083820227 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.395917: rtos_queue_send_from_isr_failed: tstamp:196083820401 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.395919: rtos_queue_send_failed: tstamp:196083822351 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.395923: rtcpu_vinotify_event: tstamp:196083905633 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196083905225 data:0x00000001
 kworker/3:0-30    [003] ....  6262.451921: rtos_queue_peek_from_isr_failed: tstamp:196085238942 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.623847: rtos_queue_peek_from_isr_failed: tstamp:196090238779 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.623851: rtos_queue_send_from_isr_failed: tstamp:196090682664 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.623852: rtos_queue_send_from_isr_failed: tstamp:196090683310 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.623854: rtos_queue_send_from_isr_failed: tstamp:196090683967 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.623855: rtos_queue_send_from_isr_failed: tstamp:196090684611 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.623856: rtos_queue_send_from_isr_failed: tstamp:196090685254 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.623857: rtos_queue_send_from_isr_failed: tstamp:196090686069 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.623858: rtos_queue_send_from_isr_failed: tstamp:196090686755 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.623859: rtos_queue_send_from_isr_failed: tstamp:196090687401 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.623861: rtos_queue_send_failed: tstamp:196090690504 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.623862: rtos_queue_send_from_isr_failed: tstamp:196090697000 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.623863: rtos_queue_send_from_isr_failed: tstamp:196090697643 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.623864: rtos_queue_send_from_isr_failed: tstamp:196090698285 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.623865: rtos_queue_send_from_isr_failed: tstamp:196090698947 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.623866: rtos_queue_send_from_isr_failed: tstamp:196090699586 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.623867: rtos_queue_send_from_isr_failed: tstamp:196090700226 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.623868: rtos_queue_send_from_isr_failed: tstamp:196090700867 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.623869: rtos_queue_send_from_isr_failed: tstamp:196090701508 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.623870: rtos_queue_send_failed: tstamp:196090704190 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.675928: rtos_queue_send_from_isr_failed: tstamp:196092313787 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.675934: rtos_queue_send_from_isr_failed: tstamp:196092313928 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.675936: rtos_queue_send_from_isr_failed: tstamp:196092314066 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.675939: rtos_queue_send_from_isr_failed: tstamp:196092314208 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.675941: rtos_queue_send_from_isr_failed: tstamp:196092314362 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.675943: rtos_queue_send_from_isr_failed: tstamp:196092314499 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.675946: rtos_queue_send_from_isr_failed: tstamp:196092314637 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.675948: rtos_queue_send_from_isr_failed: tstamp:196092314774 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.675951: rtos_queue_send_failed: tstamp:196092315345 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.675953: rtos_queue_send_from_isr_failed: tstamp:196092317058 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.675956: rtos_queue_send_from_isr_failed: tstamp:196092317196 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.675958: rtos_queue_send_from_isr_failed: tstamp:196092317335 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.675960: rtos_queue_send_from_isr_failed: tstamp:196092317474 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.675963: rtos_queue_send_from_isr_failed: tstamp:196092317611 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.675965: rtos_queue_send_from_isr_failed: tstamp:196092317749 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.675967: rtos_queue_send_from_isr_failed: tstamp:196092317886 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.675970: rtos_queue_send_from_isr_failed: tstamp:196092318024 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.675972: rtos_queue_send_failed: tstamp:196092319446 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.675976: rtcpu_vinotify_event: tstamp:196092320843 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196092319485 data:0x00000001
 kworker/3:0-30    [003] ....  6262.675978: rtcpu_vinotify_event: tstamp:196092410595 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196092410000 data:0x00000001
 kworker/3:0-30    [003] ....  6262.675981: rtcpu_vinotify_event: tstamp:196092410820 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:196092410350 data:0x00000001
 kworker/3:0-30    [003] ....  6262.675983: rtcpu_vinotify_event: tstamp:196092621200 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196092620525 data:0x00000001
 kworker/3:0-30    [003] ....  6262.731933: rtos_queue_peek_from_isr_failed: tstamp:196095238519 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.899874: rtos_queue_send_from_isr_failed: tstamp:196099184456 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.899878: rtos_queue_send_from_isr_failed: tstamp:196099185103 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.899879: rtos_queue_send_from_isr_failed: tstamp:196099185773 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.899880: rtos_queue_send_from_isr_failed: tstamp:196099186420 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.899882: rtos_queue_send_from_isr_failed: tstamp:196099187065 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.899883: rtos_queue_send_from_isr_failed: tstamp:196099187707 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.899884: rtos_queue_send_from_isr_failed: tstamp:196099188347 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.899885: rtos_queue_send_from_isr_failed: tstamp:196099188990 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.899887: rtos_queue_send_failed: tstamp:196099191748 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.899888: rtos_queue_send_from_isr_failed: tstamp:196099199040 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.899890: rtos_queue_send_from_isr_failed: tstamp:196099199678 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.899891: rtos_queue_send_from_isr_failed: tstamp:196099200317 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.899892: rtos_queue_send_from_isr_failed: tstamp:196099200957 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.899893: rtos_queue_send_from_isr_failed: tstamp:196099201639 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.899895: rtos_queue_send_from_isr_failed: tstamp:196099202280 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.899896: rtos_queue_send_from_isr_failed: tstamp:196099202923 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.899897: rtos_queue_send_from_isr_failed: tstamp:196099203564 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.899898: rtos_queue_send_failed: tstamp:196099206100 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.899899: rtos_queue_peek_from_isr_failed: tstamp:196100238528 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6262.955896: rtos_queue_send_from_isr_failed: tstamp:196100819954 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.955902: rtos_queue_send_from_isr_failed: tstamp:196100820095 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.955905: rtos_queue_send_from_isr_failed: tstamp:196100820237 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.955907: rtos_queue_send_from_isr_failed: tstamp:196100820377 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.955910: rtos_queue_send_from_isr_failed: tstamp:196100820514 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.955912: rtos_queue_send_from_isr_failed: tstamp:196100820652 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.955914: rtos_queue_send_from_isr_failed: tstamp:196100820789 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.955917: rtos_queue_send_from_isr_failed: tstamp:196100820928 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.955920: rtos_queue_send_failed: tstamp:196100821559 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.955922: rtos_queue_send_from_isr_failed: tstamp:196100823332 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6262.955924: rtos_queue_send_from_isr_failed: tstamp:196100823486 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6262.955927: rtos_queue_send_from_isr_failed: tstamp:196100823625 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6262.955929: rtos_queue_send_from_isr_failed: tstamp:196100823764 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6262.955932: rtos_queue_send_from_isr_failed: tstamp:196100823901 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6262.955934: rtos_queue_send_from_isr_failed: tstamp:196100824039 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6262.955936: rtos_queue_send_from_isr_failed: tstamp:196100824193 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6262.955939: rtos_queue_send_from_isr_failed: tstamp:196100824329 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6262.955941: rtos_queue_send_failed: tstamp:196100825701 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.067983: rtos_queue_peek_from_isr_failed: tstamp:196105238803 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6263.180004: rtos_queue_send_from_isr_failed: tstamp:196107692369 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180009: rtos_queue_send_from_isr_failed: tstamp:196107693019 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.180011: rtos_queue_send_from_isr_failed: tstamp:196107693667 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.180013: rtos_queue_send_from_isr_failed: tstamp:196107694314 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.180015: rtos_queue_send_from_isr_failed: tstamp:196107694969 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.180017: rtos_queue_send_from_isr_failed: tstamp:196107695612 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.180019: rtos_queue_send_from_isr_failed: tstamp:196107696272 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.180022: rtos_queue_send_from_isr_failed: tstamp:196107696957 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.180024: rtos_queue_send_failed: tstamp:196107699733 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180026: rtos_queue_send_from_isr_failed: tstamp:196107708135 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180029: rtos_queue_send_from_isr_failed: tstamp:196107708784 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.180031: rtos_queue_send_from_isr_failed: tstamp:196107709427 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.180033: rtos_queue_send_from_isr_failed: tstamp:196107710071 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.180035: rtos_queue_send_from_isr_failed: tstamp:196107710712 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.180037: rtos_queue_send_from_isr_failed: tstamp:196107711353 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.180039: rtos_queue_send_from_isr_failed: tstamp:196107712005 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.180041: rtos_queue_send_from_isr_failed: tstamp:196107712645 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.180043: rtos_queue_send_failed: tstamp:196107715186 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180049: rtos_queue_send_from_isr_failed: tstamp:196108834605 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180052: rtos_queue_send_from_isr_failed: tstamp:196108835252 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.180054: rtos_queue_send_from_isr_failed: tstamp:196108835896 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.180056: rtos_queue_send_from_isr_failed: tstamp:196108836546 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.180058: rtos_queue_send_from_isr_failed: tstamp:196108837378 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.180061: rtos_queue_send_from_isr_failed: tstamp:196108838134 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.180063: rtos_queue_send_from_isr_failed: tstamp:196108838775 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.180065: rtos_queue_send_from_isr_failed: tstamp:196108839417 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.180067: rtos_queue_send_failed: tstamp:196108842017 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180069: rtos_queue_send_from_isr_failed: tstamp:196108850611 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180071: rtos_queue_send_from_isr_failed: tstamp:196108851255 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.180073: rtos_queue_send_from_isr_failed: tstamp:196108851914 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.180075: rtos_queue_send_from_isr_failed: tstamp:196108852551 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.180077: rtos_queue_send_from_isr_failed: tstamp:196108853194 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.180079: rtos_queue_send_from_isr_failed: tstamp:196108853837 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.180081: rtos_queue_send_from_isr_failed: tstamp:196108854480 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.180083: rtos_queue_send_from_isr_failed: tstamp:196108855123 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.180085: rtos_queue_send_failed: tstamp:196108863831 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.180089: rtcpu_vinotify_event: tstamp:196108878811 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196108878166 data:0x00000001
 kworker/3:0-30    [003] ....  6263.180091: rtcpu_vinotify_event: tstamp:196109138606 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:196109138181 data:0x00000001
 kworker/3:0-30    [003] ....  6263.180093: rtcpu_vinotify_event: tstamp:196109139293 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196109138623 data:0x00000001
 kworker/3:0-30    [003] ....  6263.180095: rtcpu_vinotify_event: tstamp:196109139581 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196109138973 data:0x00000001
 kworker/3:0-30    [003] ....  6263.236084: rtos_queue_peek_from_isr_failed: tstamp:196110238813 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6263.236094: rtcpu_vinotify_event: tstamp:196110536524 tag:CSIMUX_FRAME channel:0x02 frame:12 vi_tstamp:196110535845 data:0x000000a0
 kworker/3:0-30    [003] ....  6263.292171: rtcpu_vinotify_event: tstamp:196111267851 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:196111267061 data:0x00000001
 kworker/3:0-30    [003] ....  6263.292184: rtcpu_vinotify_event: tstamp:196111268702 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:196111267074 data:0x00000000
 kworker/3:0-30    [003] ....  6263.292188: rtcpu_vinotify_event: tstamp:196111276775 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:196111276105 data:0x08000000
 kworker/3:0-30    [003] ....  6263.292192: rtcpu_vinotify_event: tstamp:196111563364 tag:CHANSEL_FAULT channel:0x00 frame:12 vi_tstamp:196111562690 data:0x00040200
 kworker/3:0-30    [003] ....  6263.292198: rtcpu_vinotify_event: tstamp:196111564836 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:196111563754 data:0x08000000
 kworker/3:0-30    [003] ....  6263.292204: rtcpu_vinotify_event: tstamp:196111565487 tag:CHANSEL_FAULT_FE channel:0x01 frame:12 vi_tstamp:196111564084 data:0x00000001
 kworker/3:0-30    [003] ....  6263.292208: rtcpu_vinotify_event: tstamp:196111566169 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:196111564088 data:0x00000000
 kworker/3:0-30    [003] ....  6263.403902: rtos_queue_peek_from_isr_failed: tstamp:196115238820 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6263.463908: rtos_queue_send_from_isr_failed: tstamp:196118092682 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.463913: rtos_queue_send_from_isr_failed: tstamp:196118093340 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.463915: rtos_queue_send_from_isr_failed: tstamp:196118093986 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.463917: rtos_queue_send_from_isr_failed: tstamp:196118094800 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.463918: rtos_queue_send_from_isr_failed: tstamp:196118095439 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.463920: rtos_queue_send_from_isr_failed: tstamp:196118096116 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.463922: rtos_queue_send_from_isr_failed: tstamp:196118096753 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.463924: rtos_queue_send_from_isr_failed: tstamp:196118097392 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.463928: rtos_queue_send_failed: tstamp:196118100260 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.463929: rtos_queue_send_from_isr_failed: tstamp:196118109564 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.463931: rtos_queue_send_from_isr_failed: tstamp:196118110204 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.463933: rtos_queue_send_from_isr_failed: tstamp:196118110845 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.463935: rtos_queue_send_from_isr_failed: tstamp:196118111498 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.463936: rtos_queue_send_from_isr_failed: tstamp:196118112135 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.463938: rtos_queue_send_from_isr_failed: tstamp:196118112774 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.463940: rtos_queue_send_from_isr_failed: tstamp:196118113410 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.463942: rtos_queue_send_from_isr_failed: tstamp:196118114046 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.463943: rtos_queue_send_failed: tstamp:196118116597 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.519927: rtos_queue_send_from_isr_failed: tstamp:196119728524 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.519933: rtos_queue_send_from_isr_failed: tstamp:196119728633 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.519936: rtos_queue_send_from_isr_failed: tstamp:196119728740 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.519939: rtos_queue_send_from_isr_failed: tstamp:196119728847 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.519941: rtos_queue_send_from_isr_failed: tstamp:196119728952 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.519944: rtos_queue_send_from_isr_failed: tstamp:196119729057 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.519946: rtos_queue_send_from_isr_failed: tstamp:196119729162 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.519949: rtos_queue_send_from_isr_failed: tstamp:196119729267 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.519953: rtos_queue_send_failed: tstamp:196119729737 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.519956: rtos_queue_send_from_isr_failed: tstamp:196119735261 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.519958: rtos_queue_send_from_isr_failed: tstamp:196119735367 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.519961: rtos_queue_send_from_isr_failed: tstamp:196119735473 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.519963: rtos_queue_send_from_isr_failed: tstamp:196119735579 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.519966: rtos_queue_send_from_isr_failed: tstamp:196119735683 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.519969: rtos_queue_send_from_isr_failed: tstamp:196119735788 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.519971: rtos_queue_send_from_isr_failed: tstamp:196119735892 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.519974: rtos_queue_send_from_isr_failed: tstamp:196119735996 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.519977: rtos_queue_send_failed: tstamp:196119736909 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.519982: rtcpu_vinotify_event: tstamp:196119870797 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196119869792 data:0x00000001
 kworker/3:0-30    [003] ....  6263.519984: rtcpu_vinotify_event: tstamp:196119871855 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:196119870142 data:0x00000001
 kworker/3:0-30    [003] ....  6263.519987: rtcpu_vinotify_event: tstamp:196119875713 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196119875067 data:0x00000001
 kworker/3:0-30    [003] ....  6263.519989: rtcpu_vinotify_event: tstamp:196119912673 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196119912262 data:0x00000001
 kworker/3:0-30    [003] ....  6263.576036: rtos_queue_peek_from_isr_failed: tstamp:196120238609 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6263.631962: rtcpu_vinotify_event: tstamp:196121994883 tag:CSIMUX_FRAME channel:0x02 frame:7 vi_tstamp:196121994207 data:0x000000a0
 kworker/3:0-30    [003] ....  6263.743967: rtos_queue_peek_from_isr_failed: tstamp:196125238835 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6263.743973: rtos_queue_send_from_isr_failed: tstamp:196126602087 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.743975: rtos_queue_send_from_isr_failed: tstamp:196126602743 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.743977: rtos_queue_send_from_isr_failed: tstamp:196126603394 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.743979: rtos_queue_send_from_isr_failed: tstamp:196126604057 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.743981: rtos_queue_send_from_isr_failed: tstamp:196126604718 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.743984: rtos_queue_send_from_isr_failed: tstamp:196126605365 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.743986: rtos_queue_send_from_isr_failed: tstamp:196126606023 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.743988: rtos_queue_send_from_isr_failed: tstamp:196126606669 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.743991: rtos_queue_send_failed: tstamp:196126609675 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.743993: rtos_queue_send_from_isr_failed: tstamp:196126617604 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.743995: rtos_queue_send_from_isr_failed: tstamp:196126618302 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.743997: rtos_queue_send_from_isr_failed: tstamp:196126618946 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.743999: rtos_queue_send_from_isr_failed: tstamp:196126619605 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.744002: rtos_queue_send_from_isr_failed: tstamp:196126620240 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.744004: rtos_queue_send_from_isr_failed: tstamp:196126620882 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.744006: rtos_queue_send_from_isr_failed: tstamp:196126621524 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.744008: rtos_queue_send_from_isr_failed: tstamp:196126622166 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.744010: rtos_queue_send_failed: tstamp:196126624784 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.799915: rtos_queue_send_from_isr_failed: tstamp:196128243202 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.799928: rtos_queue_send_from_isr_failed: tstamp:196128243341 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.799933: rtos_queue_send_from_isr_failed: tstamp:196128243480 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.799936: rtos_queue_send_from_isr_failed: tstamp:196128243620 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.799939: rtos_queue_send_from_isr_failed: tstamp:196128243757 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.799941: rtos_queue_send_from_isr_failed: tstamp:196128243895 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.799944: rtos_queue_send_from_isr_failed: tstamp:196128244031 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.799946: rtos_queue_send_from_isr_failed: tstamp:196128244168 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.799954: rtos_queue_send_failed: tstamp:196128244769 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.799959: rtos_queue_send_from_isr_failed: tstamp:196128246334 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.799962: rtos_queue_send_from_isr_failed: tstamp:196128246474 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6263.799965: rtos_queue_send_from_isr_failed: tstamp:196128246614 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6263.799969: rtos_queue_send_from_isr_failed: tstamp:196128246754 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6263.799972: rtos_queue_send_from_isr_failed: tstamp:196128246891 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6263.799979: rtos_queue_send_from_isr_failed: tstamp:196128247029 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6263.799981: rtos_queue_send_from_isr_failed: tstamp:196128247166 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6263.799984: rtos_queue_send_from_isr_failed: tstamp:196128247305 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6263.799990: rtos_queue_send_failed: tstamp:196128248670 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6263.856019: rtos_queue_peek_from_isr_failed: tstamp:196130238622 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.023996: rtos_queue_send_from_isr_failed: tstamp:196135080473 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.024010: rtos_queue_send_from_isr_failed: tstamp:196135081118 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.024013: rtos_queue_send_from_isr_failed: tstamp:196135081768 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.024016: rtos_queue_send_from_isr_failed: tstamp:196135082428 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.024021: rtos_queue_send_from_isr_failed: tstamp:196135083071 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.024023: rtos_queue_send_from_isr_failed: tstamp:196135083748 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.024028: rtos_queue_send_from_isr_failed: tstamp:196135084387 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.024031: rtos_queue_send_from_isr_failed: tstamp:196135085024 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.024038: rtos_queue_send_failed: tstamp:196135087754 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.024044: rtos_queue_send_from_isr_failed: tstamp:196135095302 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.024046: rtos_queue_send_from_isr_failed: tstamp:196135095940 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.024049: rtos_queue_send_from_isr_failed: tstamp:196135096579 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.024052: rtos_queue_send_from_isr_failed: tstamp:196135097219 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.024054: rtos_queue_send_from_isr_failed: tstamp:196135097857 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.024057: rtos_queue_send_from_isr_failed: tstamp:196135098496 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.024059: rtos_queue_send_from_isr_failed: tstamp:196135099131 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.024063: rtos_queue_send_from_isr_failed: tstamp:196135099768 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.024068: rtos_queue_send_failed: tstamp:196135102496 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.024072: rtos_queue_peek_from_isr_failed: tstamp:196135238574 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.079999: rtos_queue_send_from_isr_failed: tstamp:196136724693 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.080015: rtos_queue_send_from_isr_failed: tstamp:196136725352 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.080027: rtos_queue_send_from_isr_failed: tstamp:196136726096 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.080034: rtos_queue_send_from_isr_failed: tstamp:196136726745 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.080053: rtos_queue_send_from_isr_failed: tstamp:196136727386 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.080059: rtos_queue_send_from_isr_failed: tstamp:196136728032 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.080066: rtos_queue_send_from_isr_failed: tstamp:196136728690 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.080072: rtos_queue_send_from_isr_failed: tstamp:196136729335 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.080080: rtos_queue_send_failed: tstamp:196136732223 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.080088: rtos_queue_send_from_isr_failed: tstamp:196136741818 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.080094: rtos_queue_send_from_isr_failed: tstamp:196136742473 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.080100: rtos_queue_send_from_isr_failed: tstamp:196136743123 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.080107: rtos_queue_send_from_isr_failed: tstamp:196136743774 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.080111: rtos_queue_send_from_isr_failed: tstamp:196136744425 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.080115: rtos_queue_send_from_isr_failed: tstamp:196136745070 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.080121: rtos_queue_send_from_isr_failed: tstamp:196136745731 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.080131: rtos_queue_send_from_isr_failed: tstamp:196136746376 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.080137: rtos_queue_send_failed: tstamp:196136755297 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.080149: rtcpu_vinotify_event: tstamp:196136811008 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196136810182 data:0x00000001
 kworker/3:0-30    [003] ....  6264.080153: rtcpu_vinotify_event: tstamp:196137263928 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:196137263251 data:0x00000001
 kworker/3:0-30    [003] ....  6264.080157: rtcpu_vinotify_event: tstamp:196137306245 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196137305363 data:0x00000001
 kworker/3:0-30    [003] ....  6264.080161: rtcpu_vinotify_event: tstamp:196137307021 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196137305713 data:0x00000001
 kworker/3:0-30    [003] ....  6264.192064: rtos_queue_peek_from_isr_failed: tstamp:196140238848 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.192070: rtcpu_vinotify_event: tstamp:196140744909 tag:CSIMUX_FRAME channel:0x02 frame:9 vi_tstamp:196140744256 data:0x000000a0
 kworker/3:0-30    [003] ....  6264.307959: rtos_queue_send_from_isr_failed: tstamp:196143560756 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.307996: rtos_queue_send_from_isr_failed: tstamp:196143560935 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.308001: rtos_queue_send_from_isr_failed: tstamp:196143561111 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.308005: rtos_queue_send_from_isr_failed: tstamp:196143561286 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.308008: rtos_queue_send_from_isr_failed: tstamp:196143561460 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.308013: rtos_queue_send_from_isr_failed: tstamp:196143561632 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.308016: rtos_queue_send_from_isr_failed: tstamp:196143561814 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.308021: rtos_queue_send_from_isr_failed: tstamp:196143561988 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.308037: rtos_queue_send_failed: tstamp:196143562877 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.308043: rtos_queue_send_from_isr_failed: tstamp:196143566307 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.308045: rtos_queue_send_from_isr_failed: tstamp:196143566490 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.308048: rtos_queue_send_from_isr_failed: tstamp:196143566665 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.308053: rtos_queue_send_from_isr_failed: tstamp:196143566841 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.308056: rtos_queue_send_from_isr_failed: tstamp:196143567015 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.308061: rtos_queue_send_from_isr_failed: tstamp:196143567187 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.308064: rtos_queue_send_from_isr_failed: tstamp:196143567361 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.308069: rtos_queue_send_from_isr_failed: tstamp:196143567536 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.308074: rtos_queue_send_failed: tstamp:196143568244 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.360082: rtos_queue_send_from_isr_failed: tstamp:196145180762 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.360107: rtos_queue_send_from_isr_failed: tstamp:196145180900 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.360113: rtos_queue_send_from_isr_failed: tstamp:196145181039 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.360120: rtos_queue_send_from_isr_failed: tstamp:196145181179 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.360126: rtos_queue_send_from_isr_failed: tstamp:196145181315 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.360132: rtos_queue_send_from_isr_failed: tstamp:196145181451 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.360138: rtos_queue_send_from_isr_failed: tstamp:196145181589 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.360144: rtos_queue_send_from_isr_failed: tstamp:196145181725 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.360151: rtos_queue_send_failed: tstamp:196145182325 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.360157: rtos_queue_send_from_isr_failed: tstamp:196145188365 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.360164: rtos_queue_send_from_isr_failed: tstamp:196145188504 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.360170: rtos_queue_send_from_isr_failed: tstamp:196145188641 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.360176: rtos_queue_send_from_isr_failed: tstamp:196145188779 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.360182: rtos_queue_send_from_isr_failed: tstamp:196145188915 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.360188: rtos_queue_send_from_isr_failed: tstamp:196145189052 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.360194: rtos_queue_send_from_isr_failed: tstamp:196145189190 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.360200: rtos_queue_send_from_isr_failed: tstamp:196145189326 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.360207: rtos_queue_send_failed: tstamp:196145190715 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.360277: rtos_queue_peek_from_isr_failed: tstamp:196145238841 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.360297: rtcpu_vinotify_event: tstamp:196145551072 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:196145550414 data:0x00000001
 kworker/3:0-30    [003] ....  6264.360303: rtcpu_vinotify_event: tstamp:196145569938 tag:CSIMUX_STREAM channel:0xff frame:2 vi_tstamp:196145569272 data:0x00000001
 kworker/3:0-30    [003] ....  6264.360307: rtcpu_vinotify_event: tstamp:196145573028 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:196145572356 data:0x00000001
 kworker/3:0-30    [003] ....  6264.527965: rtos_queue_peek_from_isr_failed: tstamp:196150238865 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.583862: rtos_queue_send_from_isr_failed: tstamp:196152063791 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.583864: rtos_queue_send_from_isr_failed: tstamp:196152064005 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.583865: rtos_queue_send_from_isr_failed: tstamp:196152064184 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.583866: rtos_queue_send_from_isr_failed: tstamp:196152064360 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.583866: rtos_queue_send_from_isr_failed: tstamp:196152064534 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.583867: rtos_queue_send_from_isr_failed: tstamp:196152064708 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.583867: rtos_queue_send_from_isr_failed: tstamp:196152064882 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.583868: rtos_queue_send_from_isr_failed: tstamp:196152065055 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.583869: rtos_queue_send_failed: tstamp:196152065919 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.583870: rtos_queue_send_from_isr_failed: tstamp:196152068857 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.583870: rtos_queue_send_from_isr_failed: tstamp:196152069032 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.583871: rtos_queue_send_from_isr_failed: tstamp:196152069212 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.583872: rtos_queue_send_from_isr_failed: tstamp:196152069389 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.583872: rtos_queue_send_from_isr_failed: tstamp:196152069563 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.583873: rtos_queue_send_from_isr_failed: tstamp:196152069735 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.583873: rtos_queue_send_from_isr_failed: tstamp:196152069909 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.583874: rtos_queue_send_from_isr_failed: tstamp:196152070083 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.583875: rtos_queue_send_failed: tstamp:196152070864 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.640000: rtos_queue_send_from_isr_failed: tstamp:196153672692 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.640024: rtos_queue_send_from_isr_failed: tstamp:196153672799 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.640030: rtos_queue_send_from_isr_failed: tstamp:196153672906 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.640037: rtos_queue_send_from_isr_failed: tstamp:196153673012 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.640043: rtos_queue_send_from_isr_failed: tstamp:196153673117 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.640049: rtos_queue_send_from_isr_failed: tstamp:196153673222 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.640055: rtos_queue_send_from_isr_failed: tstamp:196153673328 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.640061: rtos_queue_send_from_isr_failed: tstamp:196153673432 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.640072: rtos_queue_send_failed: tstamp:196153673885 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.640078: rtos_queue_send_from_isr_failed: tstamp:196153680089 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.640084: rtos_queue_send_from_isr_failed: tstamp:196153680196 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.640090: rtos_queue_send_from_isr_failed: tstamp:196153680301 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.640097: rtos_queue_send_from_isr_failed: tstamp:196153680406 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.640103: rtos_queue_send_from_isr_failed: tstamp:196153680511 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.640109: rtos_queue_send_from_isr_failed: tstamp:196153680625 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.640115: rtos_queue_send_from_isr_failed: tstamp:196153680731 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.640122: rtos_queue_send_from_isr_failed: tstamp:196153680835 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.640128: rtos_queue_send_failed: tstamp:196153681754 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.696108: rtos_queue_peek_from_isr_failed: tstamp:196155239038 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.863861: rtos_queue_peek_from_isr_failed: tstamp:196160238879 queue:0x0b4b4500
 kworker/3:0-30    [003] ....  6264.863865: rtos_queue_send_from_isr_failed: tstamp:196160551510 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.863867: rtos_queue_send_from_isr_failed: tstamp:196160551688 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.863868: rtos_queue_send_from_isr_failed: tstamp:196160551864 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.863869: rtos_queue_send_from_isr_failed: tstamp:196160552040 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.863870: rtos_queue_send_from_isr_failed: tstamp:196160552214 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.863871: rtos_queue_send_from_isr_failed: tstamp:196160552386 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.863872: rtos_queue_send_from_isr_failed: tstamp:196160552560 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.863873: rtos_queue_send_from_isr_failed: tstamp:196160552734 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.863875: rtos_queue_send_failed: tstamp:196160553651 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.863876: rtos_queue_send_from_isr_failed: tstamp:196160556865 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.863877: rtos_queue_send_from_isr_failed: tstamp:196160557069 queue:0x0b4aad68
 kworker/3:0-30    [003] ....  6264.863878: rtos_queue_send_from_isr_failed: tstamp:196160557250 queue:0x0b4ac998
 kworker/3:0-30    [003] ....  6264.863879: rtos_queue_send_from_isr_failed: tstamp:196160557427 queue:0x0b4ae518
 kworker/3:0-30    [003] ....  6264.863880: rtos_queue_send_from_isr_failed: tstamp:196160557606 queue:0x0b4af2d8
 kworker/3:0-30    [003] ....  6264.863881: rtos_queue_send_from_isr_failed: tstamp:196160557779 queue:0x0b4b0098
 kworker/3:0-30    [003] ....  6264.863882: rtos_queue_send_from_isr_failed: tstamp:196160557961 queue:0x0b4b0e58
 kworker/3:0-30    [003] ....  6264.863883: rtos_queue_send_from_isr_failed: tstamp:196160558135 queue:0x0b4b1c18
 kworker/3:0-30    [003] ....  6264.863884: rtos_queue_send_failed: tstamp:196160558835 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.863885: rtos_queue_send_from_isr_failed: tstamp:196161659666 queue:0x0b4a7258
 kworker/3:0-30    [003] ....  6264.863886: rtos_queue_send_from_isr_failed: tstamp:196161659782 queue:0x0b4aad68
 kworker/3:0-30    [
Should be supported the VC identify the frame with VC ID not by sequency.
