The kernel loading process MDIO and MDC has no waveform.
gpio-388 (PG.05 |phy_reset ) out lo
It’s supposed to output high, but it’s low when I turn it on.
this is my log
log.txt (114.3 KB)
eth_0:ethernet@2310000 {
status = “okay”;
nvidia,skip_phy_start = <1>;
nvidia,mac-addr-idx = <0>;
nvidia,max-platform-mtu = <8000>;
/* 0=enable, 1=disable */
nvidia,pause_frames = <1>;
//xavier & orin: H5
nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 5) 1>;
//phy-handle = <&switch0port6>;
phy-mode = “rgmii”;
mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
switch0: switch0@0 {
compatible = "marvell,mv88e6352","marvell,mv88e6085";
#size-cells = <0>;
reg = <2>;
dsa,member = <0 0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
label = "lan0";
port@1 {
reg = <1>;
label = "lan1";
port@2 {
reg = <2>;
label = "lan2";
port@3 {
reg = <3>;
label = "lan3";
switch0port5: port@5 {
reg = <5>;
label = "dsa";
//phy-mode = "rgmii-txid";
link = <&switch1port5>;
fixed-link {
speed = <1000>;
full-duplex;
switch0port6:port@6 {
reg = <6>;
label = "cpu";
ethernet = <ð_0>;
//xavier & orin: J5
//interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
switch1: switch1@0 {
#size-cells = <0>;
reg = <4>;
dsa,member = <0 1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
label = "lan5";
port@1 {
reg = <1>;
label = "lan6";
port@2 {
reg = <2>;
label = "lan7";
port@3 {
reg = <3>;
label = "lan8";
switch1port5: port@5 {
reg = <5>;
label = "dsa";
link = <&switch0port5>;
fixed-link {
speed = <1000>;
full-duplex;
this is my device tree.
eqos_txc_pe0 {
nvidia,pins = “eqos_txc_pe0”;
nvidia,function = “eqos”;
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
eqos_td0_pe1 {
nvidia,pins = "eqos_td0_pe1";
nvidia,function = "eqos";
eqos_td1_pe2 {
nvidia,pins = "eqos_td1_pe2";
eqos_td2_pe3 {
nvidia,pins = "eqos_td2_pe3";
eqos_td3_pe4 {
nvidia,pins = "eqos_td3_pe4";
eqos_tx_ctl_pe5 {
nvidia,pins = "eqos_tx_ctl_pe5";
eqos_rd0_pe6 {
nvidia,pins = "eqos_rd0_pe6";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
eqos_rd1_pe7 {
nvidia,pins = "eqos_rd1_pe7";
eqos_rd2_pf0 {
nvidia,pins = "eqos_rd2_pf0";
eqos_rd3_pf1 {
nvidia,pins = "eqos_rd3_pf1";
eqos_rx_ctl_pf2 {
nvidia,pins = "eqos_rx_ctl_pf2";
eqos_rxc_pf3 {
nvidia,pins = "eqos_rxc_pf3";
eqos_sma_mdio_pf4 {
nvidia,pins = "eqos_sma_mdio_pf4";
eqos_sma_mdc_pf5 {
nvidia,pins = "eqos_sma_mdc_pf5";
soc_gpio17_pg4 {
nvidia,pins = "soc_gpio17_pg4";
nvidia,function = "rsvd0";
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
soc_gpio18_pg5 {
nvidia,pins = "soc_gpio18_pg5";
I have configured these pins
