Memory loss when flash L4T 35.1
Hi
I found that when I flash the 35.1 BSP into Xavier NX(8GB), the memory is only 6.7GiB
but when I flash 32.7.3 BSP into same Xavier NX, the memory is 7.6GiB,
see below picture:
could you please have a look why this happen and how to solve it? thanks,
Best Regards,
Sam
It looks to be necessary for K5.10 and Ubuntu 20.04. Not sure if you need Ubuntu desktop in your use-case. If it is not a must-have, please try to generate minimum rootfs and see it it meets your requirement. Please take a look at
Root File System — Jetson Linux<br/>Developer Guide 34.1 documentation
thanks, DaneLLL,
for now, the memory resource is ok to me, just curious about this
