We encountered NX storage shortage issue.
Currently storage usage almost exceeds 16GB.(full installation of jetpack )
Do you have experience or document for optimizing firmware size?
The full flash should not exceed the 16GB. May I know how did you install it?
To be exact, it’s 12-13 GB.
We are looking for way to reduce system image size because rest of storage is not enough for us.
Hi allen.ya,
We don’t have “a version of optimized disk size BSP”, but could can help prevent out-of-disk issue when installing sdkm.
You may need to study your use case to analyze which module might be able to removed/reduced to optimize it.
Also, we support to boot rootfs from external device.
Thus you could move files to larger storage.
