Jetson Nano Sdk Manager 14 GB of space for the Linux file system
I bought a new jetson xavier nx dev kit with 16gb mmc and no sd card. I installed a 120 GB M.2 SSD and installed it 4 times with SDK manager. But each time it created 14 GB of space for the Linux file system. I could never fix this. When I examined the sources, it asked me how many GB of space would be used during installation, but I never asked. I would be happy if you help. I tried to expand the SSD with gparted on the 3rd computer, but it didn’t work. Thanks in advance.
if you are using JetPack 5.1.2, then you should be doing this:
I had no problems when I installed JetPack 5.1.1 (Rev1).
The problem is in JetPack 5.1.2.
Thank you for your help
