Hello, NVIDIA team! I upgraded to the latest Linux kernel to deal with heat issues on my brand-new laptop. Now the 430.40 driver won’t load (it was okay on kernel 4.15).
I uninstalled it with sudo apt remove --purge nvidia* and sudo apt autoremove, then rebooted, reinstalled it and after another reboot, nvidia-settings says this:
nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:3131): GLib-GObject-CRITICAL **: 12:20:24.662: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 12:20:24.667: PRIME: Requires offloading
** Message: 12:20:24.667: PRIME: is it supported? yes
It then launches its GUI and allows me to select the PRIME card, but there’s nothing else. Screenshot: Pasteboard - Uploaded Image
modprobe nvidia says this:
thebrightside@SCHNITZELBOI:~$ sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': No such device
However, lspci says:
thebrightside@SCHNITZELBOI:~$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Device 3e98 (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f10 (rev a1)
My specs are:
thebrightside@SCHNITZELBOI:~$ inxi -Fz
System:
Host: SCHNITZELBOI Kernel: 5.2.0-10-generic x86_64 bits: 64
Desktop: Cinnamon 4.2.3 Distro: Linux Mint 19.2 Tina
Machine:
Type: Laptop System: Notebook product: N9x0TD_TF v: N/A serial: <filter>
Mobo: Notebook model: N9x0TD_TF serial: <filter> UEFI: INSYDE v: 1.07.06
date: 04/23/2019
Battery:
ID-1: BAT0 charge: 58.8 Wh condition: 58.8/62.1 Wh (95%)
CPU:
Topology: 8-Core model: Intel Core i7-9700 bits: 64 type: MCP
L2 cache: 12.0 MiB
Speed: 1314 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 3488 2: 3713
3: 3587 4: 4153 5: 1295 6: 1866 7: 1980 8: 3756
Graphics:
Device-1: Intel driver: i915 v: kernel
Device-2: NVIDIA driver: nouveau v: kernel
Display: x11 server: X.Org 1.19.6 driver: modesetting,nouveau
unloaded: fbdev,vesa tty: N/A
OpenGL: renderer: Mesa DRI Intel HD Graphics (Coffeelake 3x8 GT2)
v: 4.5 Mesa 19.0.2
Audio:
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel
Sound Server: ALSA v: k5.2.0-10-generic
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp6s0f1 state: down mac: <filter>
Device-2: Intel driver: iwlwifi
IF: wlp7s0 state: up mac: <filter>
IF-ID-1: enp0s20f0u5 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:
Local Storage: total: 2.75 TiB used: 3.03 TiB (110.2%)
ID-1: /dev/mmcblk0 model: TP02G size: 1.88 GiB
ID-2: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 1TB size: 953.87 GiB
ID-3: /dev/sda vendor: Samsung model: SSD 860 QVO 2TB size: 1.82 TiB
Partition:
ID-1: / size: 29.67 GiB used: 13.77 GiB (46.4%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /home size: 1.79 TiB used: 1.33 TiB (74.5%) fs: ext4 dev: /dev/sda2
ID-3: swap-1 size: 1.40 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
Sensors:
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nouveau temp: 41 C
Fan Speeds (RPM): N/A
Info:
Processes: 329 Uptime: 9m Memory: 31.13 GiB used: 2.30 GiB (7.4%)
Shell: bash inxi: 3.0.32
Driver Manager shows the 430 driver as selected, but also says “No proprietary drivers are in use”. Screenshot: https://pasteboard.co/IrIpjac.png
Bug report log attached.
Any help will be greatly appreciated! I really hope we can find a solution to this.
nvidia-bug-report.log.gz (2.01 MB)
