May I know if I can have both MIPI and QSFP feature on Thor at same time. Currently the AGX Thor has QSFP interface, I tested 10G, and it works well. It seems that P4071 supports QSFP interface, and P3971 supports CSI interface, I’m wondering that if it’s possible that I can use both QSFP interface and CSI interface at same time?
Yes, I believe it should work.
As long as there are no HW limitation in your custom carrier and your custom DTB and Pinmux are properly configured, I wouldn’t see a reason for it not to work.
best regards,
Andrew
