Customized carrier board for Jetson T5000
Dear support team,
We made a customized carrier board for Jetson T5000, and it supports QSFP28, MIPI, 40 expansion header interface.
Currently, if I’m using “p4071 config“ (sudo ./l4t_initrd_flash.sh p3834-0008-p4071-0000-nvme internal ), QSFP28 works well.
if I’m using “p3971 config“ (sudo ./l4t_initrd_flash.sh p3834-0008-p3971-0000-nvme internal ), MIPI, 40 pin expansion header interface works well.
I’m wondering if I can get both QSFP28, MIPI, 40 pin expansion header interface work simultaneously?
Should I add settings ( for example : dtsi modification for adding MIPI, 40 pin expansion header interface ) based on p4071?
Sorry for the late response.
Hi @kayccc ,
I have implemented the functionality I needed. :)
