• Hardware Platform (Jetson / GPU): Jetson Xavier NX (Devboard)
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1
• Issue Type( questions, new requirements, bugs) question, possible bug
**• How to reproduce the issue ? start dstest_test1_rtsp_out.py
I have a problem with the example deepstream_test1_rtsp_out.py (with sample_720.h264 as input). I can start the RTSP server successfully and receive the stream with e.g. VLC without any problems. But the stream cannot received by a streaming platform which needs the media attribute fmtp of the SDP session which is not set on the stream. Here is a copy from the output of wireshark for the SDP:
Real Time Streaming Protocol
Response: RTSP/1.0 200 OK\r\n
CSeq: 3\r\n
Content-type: application/sdp
Content-Base: rtsp://localhost:8554/ds-test/\r\n
Server: GStreamer RTSP server\r\n
Date: Thu, 24 Feb 2022 11:05:42 GMT\r\n
Content-length: 296
\r\n
Session Description Protocol
Session Description Protocol Version (v): 0
Owner/Creator, Session Id (o): - 3499268379920706973 1 IN IP4 172.17.0.2
Session Name (s): Session streamed with GStreamer
Session Information (i): rtsp-server
Time Description, active time (t): 0 0
Session Attribute (a): tool:GStreamer
Session Attribute (a): type:broadcast
Session Attribute (a): control:*
Session Attribute (a): range:npt=now-
Media Description, name and address (m): video 0 RTP/AVP 96
Connection Information (c): IN IP4 0.0.0.0
Media Attribute (a): rtpmap:96 H264/90000
Media Attribute (a): control:stream=0
Media Attribute (a): ts-refclk:local
Media Attribute (a): mediaclk:sender
It seems that the media information for the media attribute fmtp is not forwarded downstream. I tried to set config-interval of the encoder (insert-sps-pps is already on True in the given example) but the attribute is still missing.
I already tried to set the profile-level-id and packetization-mode directly in the launch string of the RTSPMediaFactory and then the fmtp attribute with these two values appears but this is not a satisfying solution (also sprop-parameter-sets is not set in this way)
Thank you in advance!
