I need to modify the gst-nvinfer plugin to do some specific things. I’m not having an issue with the code itself, per se. The issue I’m having is compiling and installing the plugin with a custom name.
I’ve made changes to the code so that it should by seen along side the default nvinfer plugin, but the element is unable to be loaded by gst_element_factory_make, and gst-inspect doesn’t see it either. So I’m not sure what I’m missing exactly.
Nothing is blacklisted. But I repeated all my steps again, and now I’m able to pick up my custom version, but the original is no longer registering. I have to clear the GStreamer cache for it to show up, but then once I try to use it, it no longer shows up under gst-inspect.
@ChrisDing See above. I’m now having the opposite problem of my original post.
I’m not changing the package name. I’m creating a modified version of gst-nvinfer, but I also need access to the original gst-nvinfer, so I need them to not conflict.
