使用命令修改启动图标:sudo ./flash.sh -k BMP --image bmp.blob jetson-nano-qspi-sd mmcblk0p1
提示错误:Error:Invalid target board - jetson-nano-qspi -sd.
使用lsusb命令查看设备列表,设备是已经连接到主机的,是哪里出错了呢?
It looks like you use the wrong configuration file for your board.
Are you using the devkit or custom board?
What’s the Model and SKU of your board?
型号是Jetson-nano-B01,不太明白SKU是什么,在哪里看
using devkit
Could you help to dump the result of following command?
$ sudo i2cdump -y 2 0x50
It’s looks wrong i2c bus selected.
Please also help to dump the result of following command:
$ sudo i2cdump -y 0 0x50
$ sudo i2cdump -y 1 0x50
Hi… 我們是請你在jetson上跑 不是在你的x86 host
Is jetson-nano-qspi-sd.conf existing on your host?
