Move from DLS to CLS licensing
My customer has 2 DLS licensing appliances in HA modus running on prem but we have some issues with it and actually want to get rid of these local DLS machines and move to CLS (cloud) type of licensing.
Can i just add a new Licensing (CLS) server in the licensing portal and move our licenses from the excisting (DLS type) license-server in the cloud? or is it possible to change the operating modus online from DLS to CLS?
Do i need Nvidia support to make this happen (to move the licenses from DLS to CSL) or can i do this myself without the need of nvidia support? Is there any documentation for this kind of licensing switch?
Thanks in advance!
Jan J.
should be really simple and nothing that needs NV Enterprise Support. You can create a new CLS instance and release the licenses from the DLS instance in the portal and add it to the CLS instance. Now you need to create a new Client license token and add this token to the VMs and that’s it.
It’s a straightforward process that doesn’t require NV Enterprise Support. Just create a new CLS instance, release the licenses from the existing DLS instance in the portal, and add them to the new CLS instance. Then, generate a new client license token, apply it to the VMs, and you’re done. However, if you want to download the videos, Click Here
