Moveit2 first cpp tutorial is not working with Isaac Sim
I am trying to run the cpp tutorial to move a Panda arm from Isaac sim by following the tutorial on MoveIt2 docs.
https://moveit.picknik.ai/main/doc/how_to_guides/isaac_panda/isaac_panda_tutorial.html
The tutorial works perfectly, which means I can control and move the robot through the Rviz visualization tools.
But however, when I follow the tutorial to crerate my first cpp project - hello_moveit package and run the sample demo, I am unable connect to the sim or control the arm.
So what I do is:
  1. Run the python script that launches the isaac sim with the robotic arm and the ROS topics
  2. Run the docker to launch the demo → which opens RViz and allows me to control the robot
But when I next run moveit cpp example (which works as expected without issac sim and with a normal simulator) it throws this error:
This means it cannot seem to connect to the published topic -
How can I run moveIt cpp such that it moves the robot in in Isaaac sim?
You probably have to update the robot configuration used by the hello_moveit example to use “topic-based ros2_control.”
Please see this section of the tutorial.
