Multiple Instances of Isaac Sim on Single Workstation
Hello Community,
We would like to use our workstation for multiple clients at the same time, that is, have multiple containerized instances of isaac-sim and connect to them externally using the Isaac WebRTC Client. I have found some references to such setups in this forum, but did not find a solution yet.
Is this possible? If yes, where can I find instructions on how to set up the system? Are multiple GPUs needed? Please let me know what I can do to make this work, thanks for the help in advance!
The information provided in the referenced discussion remains valid: running multiple containerized instances of Isaac Sim on a single workstation is not an officially supported or recommended use case.
