Murata LBEE5XV2EA on Orin NX
Hello, I have an Orin NX module running JetPack 6.2 with Ubuntu 22.04. This module has a Murata LBEE5XV2EA installed. I haven’t been able to find the installation/setup documentation needed to use the Murata on Orin NX. Could you please help? Thanks.
Please refer to Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
Hello @OswaldUK,
Were you able to solve this problem ?
best regards,
Andrew
Hello, I think this will solve: Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits
Couldn’t try it yet.
I have compiled .ko files according to the instructions from this website: ( Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits ).
But in the pdf, it says use cyfmac55572 files, but after inserting the files I got this error and I cannot see wlan0 interface. Any ideas for solution? Thanks.
690.233926] brcmfmac 0007:01:00.0: brcmf_pcie_bus_readshared: Invalid shared RAM address 0x00000000
[ 690.293943] brcmfmac 0007:01:00.0: brcmf_pcie_download_fw_nvram: Invalid shared RAM address 0x00000000
[ 696.309971] brcmfmac 0007:01:00.0: brcmf_pcie_bus_readshared: Invalid shared RAM address 0x00000000
brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac55572-pcie for chip BCM55560/2
Hello @OswaldUK,
According to this thread, it seems like that issue could be caused by a missing pcie.txt (nvram file).
Did you happen to see something similar in the instructions you followed?
best regards,
Andrew
