Hello Team.
I have two SD card development kit b01.I have flashed SD card image and image is working fine with one board. When I have connect this sd card with another kit then I am getting that device is rebooting continue.
Please provide some solution.
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB0, 12:19:12
Press CTRL-A Z for help on special keys
w[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-dd(4d362)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x70ed4
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x10080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x0008000p
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.280] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.301] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load addresw is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] boardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI …
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.523] Bootloader DTB Load Address: 0x83000000
[0000.528] BoardID = 3448, SKU = 0x0
[0000n531] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.535] Nano-SD: checking PT table on QSPI …
[0000.540] Loading NvTbootKernelDTB
[0000.605] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.677] Kernel DTB Load Address: 0x83100000
[0000.681] BoardID = 3448, SKU = 0x0
[0000.684] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.688] Nano-SD: checking PT table on QSPI …
[0000.694] Loading cboot binary
[0000.810] Verifying EBT in OdmNonSecureSBK mode
[0000.852] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.859] Bootloader downloaded successfully.
[0000.863] BoardID = 3448, SKU = 0x0
[0000.866] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.870] Nano-SD: checking PT table on QSPI …
[0000.875] PT: Partition NCT NOT found !
[0000.878] Warning: Find Partition via PT Failed
[0000.883] Next binary entry address: 0x92c00258
[0000.887] BoardId: 3448
[0000.892] Overriding pmu board id with proc board id
[0000.896] Display board id is not available
[0000.901] BoardID = 3448, SKU = 0x0
[0000.904] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.908] Nano-SD: checking PT table on QSPI …
[0001.013] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.069] /bpmp deleted
[0001.071] SC7EntryFw header found loaded at 0xff700000
[0001.259] OVR2 PMIC
[0001.261] Bpmp FW successfully loaded
[0001.264] BoardID = 3448, SKU = 0x0
[0001.267] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.271] Nano-SD: checking PT table on QSPI …
[0001.276] WB0 init successfully at 0xff780000
[0001.281] Set NvDecSticky Bits
[0001.284] GSC2 address ff53fffc value c0edbbcc
[0001.291] GSC MC Settings done
[0001.293] BoardID = 3448, SKU = 0x0
[0001.297] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.300] Nano-SD: checking PT table on QSPI …
[0001.306] TOS Image length 53680
[0001.309] Monitor size 53680
[0001.312] OS size 0
[0001.327] Secure Os AES-CMAC Verification Success!
[0001.332] TOS image cipher info: plaintext
[0001.335] Loading and Validation of Secure OS Successful
[0001.351] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.356] NvTbootPackSdramParams: start.
[0001.361] NvTbootPackSdramParams: done.
[0001.365] Tegraboot started after 51844 us
[0001.369] Basic modules init took 882854 us
[0001.373] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.378] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.384] Next stage binary read took 102860 us
[0001.388] Carveout took -126357 us
[0001.391] CPU initialization took 486792 us
[0001.395] Total time taken by TegraBoot 1346149 us
[0001.400] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:09:37, Jul 26 2021
ERROR: Error initializing runtime service trusty_fast
[0001.522] RamCode = 0
[0001.527] LPDDR4 Training: Read DT: Number of tables = 2
[0001.532] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.545] EMC Training Successful
[0001.548] 408000 not found in DVFS table
[0001.554] RamCode = 0
[0001.558] DT Write: emc-table@204000 succeeded
[0001.563] DT Write: emc-table@1600000 succeeded
[0001.567] LPDDR4 Training: Write DT: Number of tables = 2
[0001.614]
[0001.615] Debug Init done
[0001.617] Marked DTB cacheable
[0001.620] Bootloader DTB loaded at 0x83000000
[0001.625] Marked DTB cacheable
[0001.628] Kernel DTB loaded at 0x83100000
[0001.632] DeviceTree Init done
[0001.645] Pinmux applied successfully
[0001.649] gicd_base: 0x50041000
[0001.653] gicc_base: 0x50042000
[0001.656] Interrupts Init done
[0001.660] Using base:0x60005090 & irq:208 for tick-timer
[0001.665] Using base:0x60005098 for delay-timer
[0001.670] platform_init_timer: DONE
[0001.673] Timer(tick) Init done
[0001.677] osc freq = 38400 khz
[0001.681]
[0001.682] Welcome to L4T Cboot
[0001.685]
[0001.686] Cboot Version: 00.00.2018.01-t210-c952b4e6
[0001.691] calling constructors
[0001.694] initializing heap
[0001.696] initializing threads
[0001.699] initializing timers
[0001.702] creating bootstrap completion thread
[0001.707] top of bootstrap2()
[0001.709] CPU: ARM Cortex A57
[0001.712] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.717] initializing platform
[0001.724] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.729] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.733] Macronix QSPI chip present
[0001.737] SPI device register
[0001.740] init boot device
[0001.742] allocating memory for boot device(SPI)
[0001.747] registering boot device
[0001.755] QSPI bdev is already initialized
[0001.759] Enable APE clock
[0001.762] Un-powergate APE partition
[0001.765] of_register: registering tegra_udc to of_hal
[0001.770] of_register: registering inv20628-driver to of_hal
[0001.776] of_register: registering ads1015-driver to of_hal
[0001.782] of_register: registering lp8557-bl-driver to of_hal
[0001.787] of_register: registering bq2419x_charger to of_hal
[0001.793] of_register: registering bq27441_fuel_gauge to of_hal
[0001.804] gpio framework initialized
[0001.808] of_register: registering tca9539_gpio to of_hal
[0001.813] of_register: registering tca9539_gpio to of_hal
[0001.818] of_register: registering i2c_bus_driver to of_hal
[0001.824] of_register: registering i2c_bus_driver to of_hal
[0001.829] of_register: registering i2c_bus_driver to of_hal
[0001.835] pmic framework initialized
[0001.839] of_register: registering max77620_pmic to of_hal
[0001.844] regulator framework initialized
[0001.848] of_register: registering tps65132_bl_driver to of_hal
[0001.854] initializing target
[0001.860] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.868] board ID = D78, board SKU = 0
[0001.871] Skipping Z3!
[0001.876] fixed regulator driver initialized
[0001.893] initializing OF layer
[0001.896] NCK carveout not present
[0001.900] Skipping dts_overrides
[0001.904] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.920] I2C Bus Init done
[0001.923] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.933] I2C Bus Init done
[0001.936] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.946] I2C Bus Init done
[0001.949] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.959] I2C Bus Init done
[0001.961] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.972] I2C Bus Init done
[0001.974] of_children_init: Ops found for compatible string maxim,max77620
[0001.984] max77620_init using irq 118
[0001.989] register ‘maxim,max77620’ pmic
[0001.994] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.000] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.010] I2C Bus Init done
[0002.014] NCK carveout not present
[0002.023] Find /i2c@7000c000’s alias i2c0
[0002.027] get eeprom at 1-a0, size 256, type 0
[0002.036] Find /i2c@7000c500’s alias i2c2
[0002.040] get eeprom at 3-a0, size 256, type 0
[0002.045] get eeprom at 3-ae, size 256, type 0
[0002.049] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.054] I2C slave not started
[0002.057] I2C write failed
[0002.060] Writing offset failed
[0002.063] eeprom_init: EEPROM read failed
[0002.067] pm_ids_update: eeprom init failed
[0002.071] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.101] pm_ids_update: The pm board id is 3448-0000-400
[0002.108] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.116] pm_ids_update: pm id update successful
[0002.121] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.151] pm_ids_update: The pm board id is 3449-0000-400
[0002.157] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.165] pm_ids_update: pm id update successful
[0002.195] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.201] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.209] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.215] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.223] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3d:56:24
[0002.230] Plugin Manager: Parse ODM data 0x000a4000
[0002.242] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.256] Find /i2c@7000c000’s alias i2c0
[0002.260] get eeprom at 1-a0, size 256, type 0
[0002.269] Find /i2c@7000c500’s alias i2c2
[0002.273] get eeprom at 3-a0, size 256, type 0
[0002.277] get eeprom at 3-ae, size 256, type 0
[0002.281] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.287] I2C slave not started
[0002.290] I2C write failed
[0002.292] Writing offset failed
[0002.295] eeprom_init: EEPROM read failed
[0002.299] pm_ids_update: eeprom init failed
[0002.304] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.334] pm_ids_update: The pm board id is 3448-0000-400
[0002.340] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.347] pm_ids_update: pm id update successful
[0002.351] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.381] pm_ids_update: The pm board id is 3449-0000-400
[0002.388] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.395] pm_ids_update: pm id update successful
[0002.425] Add serial number:1420521015525 as DT property
[0002.433] Applying platform configs
[0002.439] platform-init is not present. Skipping
[0002.444] calling apps_init()
[0002.449] Couldn’t find GPT header
[0002.454] Proceeding to Cold Boot
[0002.457] starting app android_boot_app
[0002.461] Device state: unlocked
[0002.464] display console init
[0002.472] could not find regulator
[0002.496] hdmi cable not connected
[0002.499] is_hdmi_needed: HDMI not cDT entry for leds-pwm not found
o[0002.508] nnected, returning false
[0002.512] hdmi is not connected
[0002.515] sor0 is not supported
[0002.518] display_console_init: no valid display out_type
[0002.525] subnode volume_up is not found !
[0002.529] subnode back is not found !
[0002.533] subnode volume_down is not found !
[0002.537] subnode menu is not found !
[0002.541] Gpio keyboard init success
[0002.621] found decompressor handler: lz4-legacy
[0002.636] decompressing blob (type 1)…
[0002.702] display_resolution: No display init
[0002.706] Failed to retrieve display resolution
[0002.711] Could not load/initialize BMP blob…ignoring
[0002.786] decompressor handler not found
[0002.789] load_firmware_blob: Firmware blob loaded, entries=2
[0002.795] XUSB blob version 0 size 124416 @ 0x92ca828c
[0002.801] -------> se_aes_verify_sbk_clear: 747
[0002.805] se_aes_verify_sbk_clear: Error
[0002.809] SE operation failed
[0002.812] bl_battery_charging: connected to external power supply
[0002.821] display_console_ioctl: No display init
[0002.826] switch_backlight failed
[0002.832] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.839] MSC Partition not found
[0002.846] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.853] USP partition read failed!
[0002.856] blob_init: blob-partition USP header read failed
[0002.862] android_boot Unable to update recovery partition
[0002.867] kfs_getpartname: name = LNX
[0002.871] Loading kernel from LNX
[0002.880] Found 19 BFS partitions in “spiflash0”
[0003.201] Failed to validate boot-image
[0003.204] Set to failover in the next boot
[0003.208] fail control word = 0xdc4b3925
[0003.212] Rebooting …
Regards,
Babbelal patel
