So I wanted to ask if someone here knows another display that reliably or proven works with the Jetson. I would need a size of about 7" or less and a touch possibility.
Is there a supported hardware list or knowledge base where such things would be written down?
I’ve got an older Lilliput 7" HDMI monitor that works OK. Unfortunately, I can’t find the model number anywhere on the device, box ,or documentation.
I am now using a 10" Lilliput resistive touch monitor that is working fine at its native resolution of 1280x720 (model FA1000 NP/C/T). Multiysnc doesn’t work very well however (can’t crtl-alt-F# to a terminal session when at higher resolutions, and HDMI sound stops working). I haven’t tried touch drivers yet, but it is supposed to support linux.
I imagine most displays that can connect via HDMI would work (though it would help if it uses a common resolution, say 1280x720 or 1920x1080) so long as it outputs a valid EDID. eDP or LVDS connections have been a bit more tricky however, as noted in many threads here.
