Need cuda 10.2 on Jetson Orin modules
Jetson Orin supports only Jetpack 5.0 which has only cuda-11.4. I need earlier version of cuda for MXnet support. I am not able to find an easier solution around it. Can you please help?
There’re dependency in low layer driver, only the version from JetPack can be used.
Okay. In the installation steps of mxnet the makefile has -gencode arch=compute_72,code=sm_72 for Xavier NX and AGX Xavier`. Is it the same for AGX Orin as well?
Figured it out, for Orin modules it is 87
duplicate to topic 239068.
Please post a comment there if you have further questions.
