I am looking to capture video and still images on the Jetson AGX Xavier dev unit using the FRAMOS IMX-485C, FRAMOS IMX-530C, and OmniVision 0S08A20 evaluation modules (Not at the same time). So far I’ve had success in setting up the cameras and properly flashing the AGX Xavier unit, but I am not quite sure what to make of this error when using gstreamer.
Command: $ gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
Response:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.068354286
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
It looks like gstreamer is having a hard time picking up signal from the MIPI cameras. I think this may be due to an improper driver issue, but I’m not quite sure. Hope you all have had some experience here and know the best path forward.
Thanks for your help!
