No DP Video Output
Hi I gave little bought an nvidia jetson agx orin dev kit 64gb. However I can’t get video output from the display port. I have a native DP monitor. So I decided to configure via usb/serial port. But I cannot get the video output. Someone could help me?
The log in /var/log/Xorg.0.log is the following:
log.txt (29.3 KB)
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Hi, I finally solved by re-flashing the device with the updated firmware. Thank you
