No video output after Nvidia logo on Jetson Orin
When I turn on the Orin, after the Nvidia logo is displayed, there is no video output from the device, and the monitor goes into power-saving mode.
Hi vi3anand,
Is there any display output before?
Please share the full serial console log for further check.
I am using Jetson Orin Developer kit and the display output there before. Jetpack version is 5.1 -b147.
Which command to get the full serial console log?
Do you know what causes it not working now? (i.e. anything you did to cause this issue?)
JP5.1 is quite an old release. Could you reflash the latest JP5.1.4(R35.6.0) through SDK Manager to check if it could help?
To get the serial console log on AGX Orin devkit, please refer to the following instruction.
NVIDIA Jetson Orin AGX (ridgerun.com)
Hi @vi3anand,
Are you trying to implement a custom kernel? If so, it sounds like you might be encountering an issue with the modules. I can provide you with instructions to enable the GUI.
If this problem occurs right after flashing with the original kernel, it could be due to corrupted files in your NVIDIA downloads. I recommend cleaning up and re-downloading JetPack from scratch, then trying the flash again.
Looking forward to your response!
Jose Morera
Embedded Software Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
