No module names boto3
am getting this error when training to run the open images downloader script in the container.
Please try to install it with pip3:
$ sudo pip3 install boto3
Hmm this package should already be installed in the jetson-inference container. Which version of JetPack-L4T are you running?
If you run python3 inside the container, are you able to import boto3? Are you able to import pandas?
hi thanks
i did try that both in the mean system and after i run the container but still getting the same result. i also removed and redownloaded the jetson-interface, didnt work either.
the latest version JetPack 4.5.1
forgive me cz am new to this but how can i check that
OK, that should be fine. If you run the following, does it make error?
$ cd /path/to/your/jetson-inference
$ docker/run.sh
$ python3 -c 'import boto3'   # run this inside the container
yes it gives "no module names boto3
Are you sure you are running the python3 -c 'import boto3' command inside the container? I doubled checked the same container version you are using, and was able to import boto3 without issue.
yeah did that couple of times and didnt work so eventually i just reburned the image and started over
