No older versions than 9.2 available!
Hi, I’ve been trying to install any older version of CUDA than 9.2 but no matter what I do, I always get 9.2 Seriously, this is not funny. Any debian installation (e.g cuda-repo-ubuntu1604-9-0-local_9.0.176-1_amd64.deb) will get you nothing but 9.2.
I also tried sudo apt-get install cuda 9.0 with the results below.
PLEASE, PLEASE, PLEASE. Do make at least some older version of CUDA available!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda : Depends: cuda-9-2 (>= 9.2.88) but it is not going to be installed
cuda-core-9-0 : Depends: build-essential but it is not going to be installed
cuda-runtime-9-0 : Depends: cuda-drivers (>= 384.81) but it is not going to be installed
cuda-samples-9-0 : Depends: g++ but it is not going to be installed
Depends: freeglut3-dev but it is not going to be installed
Depends: libglu1-mesa but it is not going to be installed
Depends: libglu1-mesa-dev but it is not going to be installed
ghc : Depends: gcc but it is not going to be installed
libdleyna-core-1.0-3 : Depends: libgupnp-1.0-4 (>= 0.20.7) but it is not going to be installed
libghc-chell-quickcheck2-dev:i386 : Depends: libghc-quickcheck-dev-2.8.1-c1c85:i386
Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-chell-dev-0.4.0.1-212ae:i386
Depends: libghc-random-dev-1.1-bf26d:i386
libghc-chell-quickcheck2-prof:i386 : Depends: libghc-quickcheck-prof-2.8.1-c1c85:i386
Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-chell-prof-0.4.0.1-212ae:i386
Depends: libghc-random-prof-1.1-bf26d:i386
libghc-djinn-ghc-dev:i386 : Depends: libghc-async-dev-2.0.2-1a504:i386
Depends: libghc-containers-dev-0.5.6.2-5879d:i386
Depends: libghc-djinn-lib-dev-0.0.1.2-15054:i386
Depends: libghc-ghc-dev-7.10.3-0193f:i386
Depends: libghc-mtl-dev-2.2.1-05005:i386
Depends: libghc-transformers-dev-0.4.2.0-a5bbd:i386
libghc-djinn-ghc-prof:i386 : Depends: libghc-async-prof-2.0.2-1a504:i386
Depends: libghc-containers-prof-0.5.6.2-5879d:i386
Depends: libghc-djinn-lib-prof-0.0.1.2-15054:i386
Depends: libghc-ghc-prof-7.10.3-0193f:i386
Depends: libghc-mtl-prof-2.2.1-05005:i386
Depends: libghc-transformers-prof-0.4.2.0-a5bbd:i386
libghc-ekg-dev : Depends: libghc-aeson-dev-0.10.0.0-f3d60
Depends: libghc-ekg-core-dev-0.1.1.0-b6eca
Depends: libghc-ekg-json-dev-0.1.0.0-ba622
Depends: libghc-snap-core-dev-0.9.8.0-6839d
Depends: libghc-snap-server-dev-0.9.5.1-400cf
Depends: libghc-text-dev-1.2.2.0-2c09c
Depends: libghc-unordered-containers-dev-0.2.5.1-a371f
libghc-ekg-prof : Depends: libghc-aeson-prof-0.10.0.0-f3d60
Depends: libghc-ekg-core-prof-0.1.1.0-b6eca
Depends: libghc-ekg-json-prof-0.1.0.0-ba622
Depends: libghc-snap-core-prof-0.9.8.0-6839d
Depends: libghc-snap-server-prof-0.9.5.1-400cf
Depends: libghc-text-prof-1.2.2.0-2c09c
Depends: libghc-unordered-containers-prof-0.2.5.1-a371f
libghc-exception-transformers-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-stm-dev-2.4.4.1-b43e4:i386
Depends: libghc-transformers-compat-dev-0.4.0.4-8aa40:i386
libghc-exception-transformers-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-stm-prof-2.4.4.1-b43e4:i386
Depends: libghc-transformers-compat-prof-0.4.0.4-8aa40:i386
libghc-file-location-dev : Depends: libghc-lifted-base-dev-0.2.3.6-9276c
Depends: libghc-th-orphans-dev-0.13.0-ebdf3
Conflicts: libghc-file-location-dev:i386 but 0.4.9-3build1 is to be installed
libghc-file-location-dev:i386 : Depends: libghc-hunit-dev-1.3.0.0-65504:i386
Depends: libghc-lifted-base-dev-0.2.3.6-a45a1:i386
Depends: libghc-template-haskell-dev-2.10.0.0-519a3:i386
Depends: libghc-th-orphans-dev-0.13.0-47572:i386
Conflicts: libghc-file-location-dev but 0.4.9-3build1 is to be installed
libghc-file-location-prof : Depends: libghc-lifted-base-prof-0.2.3.6-9276c
Depends: libghc-th-orphans-prof-0.13.0-ebdf3
Conflicts: libghc-file-location-prof:i386 but 0.4.9-3build1 is to be installed
libghc-file-location-prof:i386 : Depends: libghc-hunit-prof-1.3.0.0-65504:i386
Depends: libghc-lifted-base-prof-0.2.3.6-a45a1:i386
Depends: libghc-template-haskell-prof-2.10.0.0-519a3:i386
Depends: libghc-th-orphans-prof-0.13.0-47572:i386
Conflicts: libghc-file-location-prof but 0.4.9-3build1 is to be installed
libghc-generic-deriving-dev : Conflicts: libghc-generic-deriving-dev:i386 but 1.9.0-1 is to be installed
libghc-generic-deriving-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-ghc-prim-dev-0.4.0.0-bf246:i386
Conflicts: libghc-generic-deriving-dev but 1.9.0-1 is to be installed
libghc-generic-deriving-prof : Conflicts: libghc-generic-deriving-prof:i386 but 1.9.0-1 is to be installed
libghc-generic-deriving-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-ghc-prim-prof-0.4.0.0-bf246:i386
Conflicts: libghc-generic-deriving-prof but 1.9.0-1 is to be installed
libghc-haskelldb-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-directory-dev-1.2.2.0-97fb5:i386
Depends: libghc-old-locale-dev-1.0.0.7-5aedb:i386
Depends: libghc-old-time-dev-1.1.0.3-1d003:i386
Depends: libghc-pretty-dev-1.1.2.0-05f1b:i386
Depends: libghc-time-dev-1.5.0.1-f2449:i386
libghc-haskelldb-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-directory-prof-1.2.2.0-97fb5:i386
Depends: libghc-old-locale-prof-1.0.0.7-5aedb:i386
Depends: libghc-old-time-prof-1.1.0.3-1d003:i386
Depends: libghc-pretty-prof-1.1.2.0-05f1b:i386
Depends: libghc-time-prof-1.5.0.1-f2449:i386
libghc-hslogger-dev : Depends: libghc-mtl-dev-2.2.1-3af90
Depends: libghc-old-locale-dev-1.0.0.7-0db93
libghc-hslogger-prof : Depends: libghc-mtl-prof-2.2.1-3af90
Depends: libghc-old-locale-prof-1.0.0.7-0db93
libghc-http-types-dev : Depends: libghc-blaze-builder-dev-0.4.0.1-073b5
Depends: libghc-case-insensitive-dev-1.2.0.5-aaffb
libghc-http-types-prof : Depends: libghc-blaze-builder-prof-0.4.0.1-073b5
Depends: libghc-case-insensitive-prof-1.2.0.5-aaffb
libghc-hxt-unicode-dev : Conflicts: libghc-hxt-unicode-dev:i386 but 9.0.2.4-4 is to be installed
libghc-hxt-unicode-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-hxt-charproperties-dev-9.2.0.1-48917:i386
Conflicts: libghc-hxt-unicode-dev but 9.0.2.4-4 is to be installed
libghc-hxt-unicode-prof : Conflicts: libghc-hxt-unicode-prof:i386 but 9.0.2.4-4 is to be installed
libghc-hxt-unicode-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-hxt-charproperties-prof-9.2.0.1-48917:i386
Conflicts: libghc-hxt-unicode-prof but 9.0.2.4-4 is to be installed
libghc-pandoc-citeproc-dev : Depends: libghc-aeson-dev-0.10.0.0-f3d60
Depends: libghc-data-default-dev-0.5.3-e05c4
Depends: libghc-pandoc-dev-1.16.0.2-492c1
Depends: libghc-pandoc-types-dev-1.16.1-f7948
Depends: libghc-parsec-dev-3.1.9-c97a6
Depends: libghc-tagsoup-dev-0.13.6-346bc
Depends: libghc-text-icu-dev-0.7.0.1-86417
Depends: libghc-xml-conduit-dev-1.3.3-1ee69
Depends: libghc-yaml-dev-0.8.15.2-a4eb8
libghc-pandoc-citeproc-prof : Depends: libghc-aeson-prof-0.10.0.0-f3d60
Depends: libghc-data-default-prof-0.5.3-e05c4
Depends: libghc-pandoc-prof-1.16.0.2-492c1
Depends: libghc-pandoc-types-prof-1.16.1-f7948
Depends: libghc-parsec-prof-3.1.9-c97a6
Depends: libghc-tagsoup-prof-0.13.6-346bc
Depends: libghc-text-icu-prof-0.7.0.1-86417
Depends: libghc-xml-conduit-prof-1.3.3-1ee69
Depends: libghc-yaml-prof-0.8.15.2-a4eb8
libghc-reform-happstack-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-bytestring-dev-0.10.6.0-89a6f:i386
Depends: libghc-happstack-server-dev-7.4.5-4f35f:i386
Depends: libghc-reform-dev-0.2.7.1-427a4:i386
Depends: libghc-text-dev-1.2.2.0-5a148:i386
Depends: libghc-utf8-string-dev-1.0.1.1-5395e:i386
libghc-reform-happstack-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-bytestring-prof-0.10.6.0-89a6f:i386
Depends: libghc-happstack-server-prof-7.4.5-4f35f:i386
Depends: libghc-reform-prof-0.2.7.1-427a4:i386
Depends: libghc-text-prof-1.2.2.0-5a148:i386
Depends: libghc-utf8-string-prof-1.0.1.1-5395e:i386
libghc-regex-base-dev : Depends: libghc-mtl-dev-2.2.1-3af90
libghc-regex-base-prof : Depends: libghc-mtl-prof-2.2.1-3af90
libghc-word-trie-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-binary-dev-0.7.5.0-35c4b:i386
libghc-word-trie-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-binary-prof-0.7.5.0-35c4b:i386
libghc-xmonad-contrib-dev:i386 : Depends: libghc-x11-dev-1.6.1.2-ab4e3:i386
Depends: libghc-x11-xft-dev-0.3.1-a4270:i386
Depends: libghc-extensible-exceptions-dev-0.1.1.4-81599:i386
Depends: libghc-filepath-dev-1.4.0.0-59267:i386
Depends: libghc-process-dev-1.2.3.0-c6360:i386
Depends: libghc-unix-dev-2.7.1.0-7648c:i386
Depends: libghc-xmonad-dev-0.12-085f7:i386
libghc-xmonad-contrib-prof:i386 : Depends: libghc-x11-prof-1.6.1.2-ab4e3:i386
Depends: libghc-x11-xft-prof-0.3.1-a4270:i386
Depends: libghc-extensible-exceptions-prof-0.1.1.4-81599:i386
Depends: libghc-filepath-prof-1.4.0.0-59267:i386
Depends: libghc-process-prof-1.2.3.0-c6360:i386
Depends: libghc-unix-prof-2.7.1.0-7648c:i386
Depends: libghc-xmonad-prof-0.12-085f7:i386
libgtkdataboxmm-0.9-0 : Depends: libatkmm-1.6-1v5 (>= 2.22.1) but it is not going to be installed
Depends: libglibmm-2.4-1v5 (>= 2.44.0) but it is not going to be installed
Depends: libgtkmm-2.4-1v5 (>= 1:2.24.0) but it is not going to be installed
Depends: libsigc+±2.0-0v5 (>= 2.2.0) but it is not going to be installed
libgupnp-av-1.0-2 : Depends: libgupnp-1.0-4 (>= 0.18.0) but it is not going to be installed
libipaddr-ocaml-dev : Depends: libsexplib-camlp4-dev-n4n51
Depends: ocaml-nox-4.02.3
libogg-ocaml-dev : Depends: ocaml-nox-4.02.3
libogre-1.9.0v5 : Depends: libfreeimage3 but it is not going to be installed
Depends: libglu1-mesa but it is not going to be installed or
libglu1
liboxideqt-qmlplugin : Depends: liboxideqtcore0 (= 1.21.5-0ubuntu0.16.04.1) but it is not going to be installed
Depends: liboxideqtquick0 (= 1.21.5-0ubuntu0.16.04.1) but it is not going to be installed
libqt5network5 : Depends: libproxy1v5 (>= 0.4.11) but it is not going to be installed
libqt5qml5 : Depends: libdouble-conversion1v5 (>= 2.0.0) but it is not going to be installed
librest-0.7-0 : Depends: libsoup-gnome2.4-1 (>= 2.27.4) but it is not going to be installed
Depends: libsoup2.4-1 (>= 2.30) but it is not going to be installed
network-manager-gnome : Depends: network-manager (>= 1.2) but it is not going to be installed
pulseaudio : Depends: libasound2-plugins but it is not going to be installed
qtdeclarative5-ubuntu-ui-toolkit-plugin : Depends: qml-module-ubuntu-components
Depends: qml-module-ubuntu-layouts but it is not going to be installed
Depends: qml-module-ubuntu-performancemetrics
Depends: qml-module-ubuntu-test but it is not going to be installed
ubuntu-system-settings : Depends: libubuntuoneauth-2.0-0 (>= 13.08) but it is not going to be installed
Depends: indicator-network (>= 0.7.1)
Depends: powerd (>= 0.15) but it is not going to be installed or
gnome-settings-daemon but it is not going to be installed
ubuntu-system-settings-online-accounts : Depends: qtdeclarative5-accounts-plugin (>= 0.6) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
sudo apt-get install cuda-9-0
Thanks! Damn I feel so stupid but at the same time I’m so glad!!!
