I’m currently using RTX5000 and 16GB ram. I has installed ISAAC SIM(Release:2023.1.1) successfully through Omniverse Launcher. but here is no response when i push the “LAUNCH” button.
And also, I conducted “/home/username/.local/share/ov/pkg/isaac_sim-2023.1.1/isaac-sim.sh -v
I encountered “Segmentation fault”.
So, I attached the isaac_sim log file. My operating conditions are below.
Can I get some help? Please thanks in advance.
omni.isaac.sim.post.install.log (40.7 KB)
Plus, I assume that It is the recognition problem of gpu accouding to the trouble shooting guide.
I tried to remove the vulkan two icd folders then I got a GPU Foundation issue when i push the launch button.(refer to the attached image)
And also, I attach the new log file when I run execution command in therminal window.
kit_20240130_104837.log (795.7 KB)
Hi. Do you get the same error when running USD Composer?
Try uninstall the driver and remove/uninstall the vulkan files, then reinstall the 525 drivers.
If it does not work, try the 535.154.05 drivers.
Hi, thanks for your response. I follow it but it doesn’t work.
I remove the current driver and re-install the next drivers.
- 525.147.05
- 525.85.05
- 535.154.05
However, the problem still remains when I implemented Isaac sim both pushing lauch button and typing start command.
Please give some tips to solve it
kit_20240131_142503.log (765.8 KB)
Hi. Are you running natively with a physical monitor connected to the RTX 5000 or on a VM.
It looks like your display is not setup correctly.
Try running xrandr
If running on VM or headless, you need to correctly do the X forwarding.
I directly connect my monitor to the RTX 5000.
I have attached the screen shot of “xrandr” command.
Please, give me some tips to solve this problem.
Thanks,
Hello, Did you successfully install CUDA?
you should use nvcc --version to check your CUDA installation
Link: https://www.youtube.com/watch?v=8i3BiWa5AZ4
From my experience, if you have CUDA, Cache, and Isaac Sim install then it should work fine.
Also, make sure that the CUDA version match with your GPU version
Hi, thank you for your response.
I guess there used to be a problem between NVIDIA graphic driver and Isacc Sim.
After re-installing ubuntu and the graphic driver, It work well now.
