I just started having an issue with the HDMI port on my Jetson Nano. Today, the HDMI output on my Nano stopped working (seemingly out of nowhere). It has worked without issue before this, and I can connect other devices to the monitor via HDMI and that is fine, so the issue is not the HDMI cable or the display.
I am able to successfully ssh into the Nano, so it boots and operates fine. I have tried to run it both on a 5V4A power supply and the USB C port, and neither works.
Do I need to re-flash the SD card? Any other solutions?
