• Hardware Platform (Jetson / GPU) Jeston (Orin Nano)
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.2
We are using Jeston Orin Nano, DeepStream SDK 6.2, Jetpack 5.1 and TensorRT 8.5.2
Using the below code
def load_engine(trt_runtime, engine_path):
with open(engine_path, “rb”) as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
trt_engine_path = “resnet34_peoplenet.tlt”
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_runtime = trt.Runtime(TRT_LOGGER)
trt_engine = load_engine(trt_runtime, trt_engine_path)
I am getting the error as below
[11/09/2023-16:51:46] [TRT] [E] 1: [stdArchiveReader.cpp::StdArchiveReader::32] Error Code 1: Serialization (Serialization assertion magicTagRead == kMAGIC_TAG failed.Magic tag does not match)
[11/09/2023-16:51:46] [TRT] [E] 4: [runtime.cpp::deserializeCudaEngine::65] Error Code 4: Internal Error (Engine deserialization failed.)
Kindly help on the query
