The Stat System View does not show result. Setting the enviornment virable PYTHONIOENCODING=UTF-8 does not resolve the issue. This may be the similar issue posted here Nsight Compute won't run on non-english windows - #5 by Sanjiv.Satoor.
This issue has been addressed and fixed, but the fix has not made it to a public release just yet.
Until then, as a workaround you can set the variable NSYS_PYTHONIOENCODING.
Because Nsys is often used to profile Python applications, the internal version of Python uses a different set of environment variables, prefaced with NSYS_. This is to avoid conflict between configuration settings for the internal Python vs other Python instances.
The workaround works. Thank you.
