I have 960M and Windows 10, vs2015 and the lastest nsight version. (and TDR of 30 seconds)
I can launch my OpenGL application with graphics debugging but when I click on the button “pause and capture frame” on the hud, it crashes with the message : “3d engine has quit unexpectedly”. However, my application works fine.
I think that’s due to you are using Laptop with Win10, which means you are under Win10 Hybrid Graphics mode, and that will make the crash happen on Nsight.
Could you please just disable the iGPU and Win10 will disable hybrid mode, you can continue use Nsight without crash.
I have a similar issue. When I start my application in graphics debug mode, it runs fine. When I try to click “Pause and Capture Frame”, the application and debugger crash without any dialog or error message. In the logfile in %AppData%\NVIDIA Corporation\Nsight\Monitor\1.0\Logs, this was the output:
Error,10/27/2016 11:37:33,Nsight.Monitor.exe,‘Win32’ id: 9,[Messaging],"Could not get childnode 20bbbe0 203a8 from Context
",MultiProducerMessageQueue.ProcessNextMessage => MultiProducerMessageQueue.ProcessMessage => MultiProducerMessageQueue.ExecuteFunctorDelegate => <>c__DisplayClass1.<Nvda.Messaging.Interop.IMessageCallback.HandleMessages>b__0 => NLogLogger.Log => NLogLogger.LogCore => LoggerImpl.Write
Error,10/27/2016 11:54:04,Nsight.Monitor.exe,‘Win32’ id: 9,[Messaging],"Could not get childnode 3aa050 203a8 from Context
I am running Nsight Visual Studio 5.0 in VS2015, separate machines for host and target, target has GTX 560 and driver version 362.00. This debugger used to function before a few seemingly innocuous changes to non-OpenGL code in our engine.
