Hi.
As alternative, you can run the nucleus server in your own container following the next steps (this is how I am running the nucleus because I don’t have superuser access in the server, and it works very well). I hope they are useful to you :)
Create a Nucleus docker image if the Nucleus Deployment could not be done
Download and run an Ubuntu 18.04 container
docker pull ubuntu:18.04
docker run --name omniverse-nucleus-template-base --interactive --entrypoint /bin/bash --detach ubuntu:18.04
Upload the Linux installer to the remote workstation and copy it into the container
docker cp omniverse-nucleus-2019.3A.2282-1-linux-installer.run omniverse-nucleus-template-base:/home
Execute the container and install Nucleus
docker exec -it omniverse-nucleus-template-base bash
Install dependencies
apt update
apt install libpython2.7
apt install tmux
apt install sudo
Install Nucleus
cd /home
sudo chmod +x omniverse-nucleus-2019.3A.2282-1-linux-installer.run
sudo ./omniverse-nucleus-2019.3A.2282-1-linux-installer.run
rm omniverse-nucleus-2019.3A.2282-1-linux-installer.run
Commit the modified container to a docker image
Detach from the docker container using the key sequence Ctrl + P Ctrl + Q and commit the changes
docker commit omniverse-nucleus-template-base omniverse-nucleus-template
To see the committed image (omniverse-nucleus-template) use the command docker images.
Also, the running container could be removed (omniverse-nucleus-template-base)
docker stop omniverse-nucleus-template-base
docker rm omniverse-nucleus-template-base
Run the container and start services (server & web)
docker run -it --name omniverse-nucleus-sample --entrypoint /bin/bash -p 2000-2001:2000-2001 -p 3020:3020 -p 3030:3030 -p 3100:3100 -p 3120:3120 -p 3180:3180 -p 3333:3333 -p 3400:3400 -p 9500:9500 -p 3007-3009:3007-3009 -p 8080:8080 omniverse-nucleus-template
Start service: server
tmux new -s server
cd /var/lib/omniverse/server
/opt/nvidia/omniverse/server/omni.server.app -input false
Detach current tmux session using Ctrl + b d. Note: if there is a nested tmux session use Ctrl + b Ctrl + b d
Start service: web
tmux new -s web
cd /var/lib/omniverse/web
/opt/nvidia/omniverse/web/OmniverseWeb
