Hi Dane,
Thanks for the reply.
I tested the original nvbuf_util
library and it doesn’t have problem with copying buffer. I did the test similarly to Copying YUV420 buffer using NvBufferTransform cause pixel value change - #7 by kazunori.kimura
However, the my issue above persists even with the patched library.
