I have started using cuda and compiling using visual studio 13 and cuda toolkit 7.5.
I had an issue when trying to compile simple files so I tried on the cmd prompt. I did change the Path environment variable to include the path to cl.exe.
Since then, I keep getting the error message nvcc.exe is not a valid win32 application even when trying to build it through VS13.
I have remove the path to cl.exe rom the Path environment variable and restarted the computer but I still get the same error message. (I have also googled this and tried the few solutions proposed)
Is there something else that I can try to do to solve this?
