Hi All,
While going through the NVCSI_PHY_0_NVCSI_CIL_A_CONTROL_0 register in parker_TRM document, there is a field called ‘THS_SETTLE’ in the register.
it is given in description of THS_SETTLE field as,
Settle time for data lane when moving from LP to HS (LP11->LP01->LP00), this setting determines how
many LP clock cycles (204 MHz lp clock cycles) to wait, after LP00, before starting to look at the data. 85ns + 6 * UI < (Ths-
settle-programmed + 6) * lp clock periods < 145ns + 10 * UI
What is UI(unit interval) ?
How to calculate this value ?
thanks in advance…
