Nvdrmvideosink doesn't work on Orin Nano Super (JP6.2) with HDMI converter
Hello!
My HW:
-Orin Nano Super (JP 6.2).
-DisplayPort-to-HDMI converter.
I have such running script for gstreamer:
  gst-launch-1.0 -e \
  filesrc location=~/dashcam.mp4 ! \
  qtdemux ! \
  h264parse ! \
  nvv4l2decoder ! \
  nvvidconv ! \
    "video/x-raw(memory:NVMM), format=NV12" ! \
  nvdrmvideosink conn_id=0 plane_id=2 sync=false
It’s working fine on Xavier NX JP5.2 (Dispaly connected via HDMI). But when trying it on Jetson Orin with JP6.2, it fails
When running in text mode:
 gst-launch-1.0 -e \
>   qtdemux ! \
>   h264parse ! \
>   nvv4l2decoder ! \
>   nvvidconv ! \
Setting pipeline to PAUSED ...
Could not open DRM failed
ERROR: from element /GstPipeline:pipeline0/GstNvDrmVideoSink:nvdrmvideosink0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
../libs/gst/base/gstbasesink.c(5878): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNvDrmVideoSink:nvdrmvideosink0:
Failed to start
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL ...
Freeing pipeline ...
~$ sudo modetest -M tegra
Encoders:
id      crtc    type    possible crtcs  possible clones
Connectors:
id      encoder status          name            size (mm)       modes   encoders
CRTCs:
id      fb      pos     size
Planes:
id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
Frame buffers:
id      size    pitch
When runing in GDM mode:
  gst-launch-1.0 -e \
>   qtdemux ! \
  nvvi>   h264parse ! \
>   nvv4l2decoder ! \
>   nvvidconv ! \
Opening in BLOCKING MODE
Pipeline is PREROLLING ...
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
ERROR: from element /GstPipeline:pipeline0/GstQTDemux:qtdemux0: Internal data stream error.
../gst/isomp4/qtdemux.c(6760): gst_qtdemux_loop (): /GstPipeline:pipeline0/GstQTDemux:qtdemux0:
streaming stopped, reason not-negotiated (-4)
sudo modetest -M nvidia-drm
[sudo] password for orca:
Encoders:
62      0       TMDS    0x00000003      0x00000000
64      0       TMDS    0x00000003      0x00000000
Connectors:
63      0       connected       DP-1            480x270         23      62, 64
  modes:
        index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
  #0 1920x1080 60.00 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: preferred
  #1 1920x1080 59.94 1920 2008 2052 2200 1080 1084 1089 1125 148350 flags: phsync, pvsync; type:
  #2 1920x1080 50.00 1920 2448 2492 2640 1080 1084 1089 1125 148500 flags: phsync, pvsync; type:
  #3 1680x1050 59.95 1680 1784 1960 2240 1050 1053 1059 1089 146250 flags: nhsync, pvsync; type:
  #4 1400x1050 59.98 1400 1488 1632 1864 1050 1053 1057 1089 121750 flags: nhsync, pvsync; type:
  #5 1600x900 60.00 1600 1624 1704 1800 900 901 904 1000 108000 flags: phsync, pvsync; type:
  #6 1280x1024 75.02 1280 1296 1440 1688 1024 1025 1028 1066 135000 flags: phsync, pvsync; type:
  #7 1280x1024 60.02 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type:
  #8 1440x900 59.89 1440 1520 1672 1904 900 903 909 934 106500 flags: nhsync, pvsync; type:
  #9 1280x800 59.81 1280 1352 1480 1680 800 803 809 831 83500 flags: nhsync, pvsync; type:
  #10 1152x864 75.00 1152 1216 1344 1600 864 865 868 900 108000 flags: phsync, pvsync; type:
  #11 1280x720 60.00 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type:
  #12 1280x720 59.94 1280 1390 1430 1650 720 725 730 750 74180 flags: phsync, pvsync; type:
  #13 1280x720 50.00 1280 1720 1760 1980 720 725 730 750 74250 flags: phsync, pvsync; type:
  #14 1024x768 75.03 1024 1040 1136 1312 768 769 772 800 78750 flags: phsync, pvsync; type:
  #15 1024x768 60.00 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type:
  #16 800x600 75.00 800 816 896 1056 600 601 604 625 49500 flags: phsync, pvsync; type:
  #17 800x600 60.32 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type:
  #18 720x576 50.00 720 732 796 864 576 581 586 625 27000 flags: nhsync, nvsync; type:
  #19 720x480 59.94 720 736 798 858 480 489 495 525 27000 flags: nhsync, nvsync; type:
  #20 640x480 75.00 640 656 720 840 480 481 484 500 31500 flags: nhsync, nvsync; type:
  #21 640x480 59.94 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type:
  #22 640x480 59.93 640 656 752 800 480 490 492 525 25170 flags: nhsync, nvsync; type:
  props:
        1 EDID:
                flags: immutable blob
                blobs:
                value:
                        00ffffffffffff001e6db85a01010101
                        0118010380301b78ea3135a5554ea126
                        0c5054a54b00714f81809500b300a9c0
                        810081c09040023a801871382d40582c
                        4500e00e1100001e000000fd00384b1e
                        530f000a202020202020000000fc004c
                        47204950532046554c4c4844000000ff
                        000a2020202020202020202020200164
                        02031df14a900403011412051f101323
                        0907078301000065030c001000023a80
                        1871382d40582c4500e00e1100001e01
                        1d8018711c1620582c2500e00e110000
                        9e011d007251d01e206e285500e00e11
                        00001e8c0ad08a20e02d10103e9600e0
                        0e110000180000000000000000000000
                        000000000000000000000000000000ae
        2 DPMS:
                flags: enum
                enums: On=0 Standby=1 Suspend=2 Off=3
                value: 0
        5 link-status:
                flags: enum
                enums: Good=0 Bad=1
                value: 0
        6 non-desktop:
                flags: immutable range
                values: 0 1
                value: 0
        4 TILE:
                blobs:
                value:
        65 vrr_capable:
                values: 0 1
                value: 0
CRTCs:
id      fb      pos     size
43      0       (0,0)   (0x0)
  #0  nan 0 0 0 0 0 0 0 0 0 flags: ; type:
  props:
        24 VRR_ENABLED:
                flags: range
                values: 0 1
                value: 0
56      0       (0,0)   (0x0)
  props:
        24 VRR_ENABLED:
                flags: range
                values: 0 1
                value: 0
Planes:
36      0       0       0,0             0,0     0               0x00000001
  formats: AR15 XR15 RG16 AR24 XR24 AB30 XB30 AB24 XB24 AB4H YUYV UYVY NV42 NV24 NV61 NV16 NV21 NV12 P210 P010 P012 XB4H
  props:
        8 type:
                flags: immutable enum
                enums: Overlay=0 Primary=1 Cursor=2
                value: 1
        30 IN_FORMATS:
                blobs:
                value:
                        01000000000000001600000018000000
                        07000000700000004152313558523135
                        52473136415232345852323441423330
                        58423330414232345842323441423448
                        59555956555956594e5634324e563234
                        4e5636314e5631364e5632314e563132
                        50323130503031305030313258423448
                        ffff3f00000000000000000000000000
                        1560600000000003ffff3f0000000000
                        00000000000000001460600000000003
                        1360600000000003ffff3f0000000000
                        00000000000000001260600000000003
                        1160600000000003ffff3f0000000000
                        00000000000000001060600000000003
                        0000000000000000
                in_formats blob decoded:
                         AR15:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         XR15:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         RG16:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         AR24:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         XR24:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         AB30:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         XB30:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         AB24:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         XB24:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         AB4H:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         YUYV:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         UYVY:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         NV42:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         NV24:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         NV61:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         NV16:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         NV21:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         NV12:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         P210:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         P010:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         P012:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
                         XB4H:  NVIDIA_BLOCK_LINEAR_2D,HEIGHT=5,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=4,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=3,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=2,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=1,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 NVIDIA_BLOCK_LINEAR_2D,HEIGHT=0,KIND=6,GEN=2,SECTOR=1,COMPRESSION=0 LINEAR
        34 NV_INPUT_COLORSPACE:
                flags: enum
                enums: None=0 IEC 61966-2-2 linear FP=1 ITU-R BT.2100-PQ YCbCr=2
                value: 0
        35 NV_HDR_STATIC_METADATA:
                flags: blob
                blobs:
                value:
        38 rotation:
                flags: bitmask
                values: rotate-0=0x1 rotate-180=0x4 reflect-x=0x10 reflect-y=0x20
                value: 1
39      0       0       0,0             0,0     0               0x00000001
  formats: AR24
  props:
        8 type:
                value: 2
        30 IN_FORMATS:
                blobs:
                value:
                        01000000000000000100000018000000
                        01000000200000004152323400000000
                        01000000000000000000000000000000
                        0000000000000000
                         AR24:  LINEAR
        41 alpha:
                flags: range
                values: 0 65535
                value: 65535
        42 pixel blend mode:
                flags: enum
                enums: Pre-multiplied=0 Coverage=1
                value: 0
44      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 0
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                flags: enum
                value: 0
                flags: blob
                blobs:
                value:
        46 alpha:
                flags: range
                values: 0 65535
                value: 65535
        47 pixel blend mode:
                flags: enum
                value: 0
        48 rotation:
                flags: bitmask
                value: 1
49      0       0       0,0             0,0     0               0x00000002
  props:
        8 type:
                value: 1
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                flags: enum
                value: 0
                flags: blob
                blobs:
                value:
        51 rotation:
                flags: bitmask
                value: 1
52      0       0       0,0             0,0     0               0x00000002
  formats: AR24
  props:
        8 type:
                value: 2
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                         AR24:  LINEAR
        54 alpha:
                flags: range
                values: 0 65535
                value: 65535
        55 pixel blend mode:
                flags: enum
                value: 0
57      0       0       0,0             0,0     0               0x00000002
  props:
        8 type:
                value: 0
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                flags: enum
                value: 0
                flags: blob
                blobs:
                value:
        59 alpha:
                flags: range
                values: 0 65535
                value: 65535
        60 pixel blend mode:
                flags: enum
                value: 0
        61 rotation:
                flags: bitmask
                value: 1
Frame buffers:
id      size    pitch
I am using DisplayPort-to-HDMI converter. Could that be the issue? I see DRM driver doesn’t recognize my display in Multi User Target (Text Mode). If converter is the issue, why then it could recognize display behind converter in the graphical mode, but still fails to start?
That GST starting script is working on the my Orin Nano only if replace nvdrmvideosinkwith xvimagesink. So I know that GST can work fine on this device.
I really need to make it work with HDMI converter as there is no native HDMI port on the Orin Nano DevBoard, and for our embeded system we are using HDMI-to-AV converter (I couldn’t find any other that supports DispalyPort). It’s also important that streamed video to GST should be rendered over aything else on the screen.
We don’t observe the issue with our DP to HDMI converter. Please make sure you have followed the steps to disable display manager and load DRM driver:
Accelerated GStreamer — NVIDIA Jetson Linux Developer Guide
Hey @DaneLLL !
Huge thanks! 🙏
It’s working now!
Kind regards.
