NVFORTRAN 26.5 aborts while compiling the following standard-conforming Fortran 2008 program whenever a -Ktrap option is specified, including -Ktrap=none.
I previously reproduced the same failure with NVFORTRAN 26.3.
Environment
nvfortran 26.5-0 64-bit target on x86-64 Linux -tp cascadelake
NVIDIA Compilers and Tools
Copyright (c) 2026, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Minimal reproducer
Save as reproducer.f90:
subroutine convert(words, values)
use iso_fortran_env, only: int64, real64
implicit none
integer(int64), intent(in) :: words
real(real64), intent(out) :: values
values = real(shiftr(words, 8), real64) / 256.0_real64
end subroutine convert
Compile with:
nvfortran -O0 -Ktrap=fp -c reproducer.f90
The compiler exits with status 2:
Intrinsic has incorrect argument type!
ptr @llvm.experimental.constrained.fdiv.f64
LLVM ERROR: Broken module found, compilation aborted!
PLEASE submit a bug report to https://github.com/llvm/llvm-project/issues/ and include the crash backtrace.
nvfortran-Fatal-/home/pedro/software/nvidia/hpc_sdk/Linux_x86_64/26.5/compilers/share/llvm/bin/llc TERMINATED by signal 6
The same failure and exit status occur with:
nvfortran -O0 -Ktrap=none -c reproducer.f90
In contrast, omitting -Ktrap succeeds with exit status 0:
nvfortran -O0 -c reproducer.f90
Thus, even -Ktrap=none activates a code-generation path that produces an invalid declaration or call of llvm.experimental.constrained.fdiv.f64.
Workaround
Materializing the result of SHIFTR before converting it to REAL avoids the failure:
implicit none
integer(int64) :: shifted
shifted = shiftr(words, 8)
values = real(shifted, real64) / 256.0_real64
This version compiles successfully with exit status 0:
nvfortran -O0 -Ktrap=fp -c workaround.f90
Thanks in advance for looking into this!
