Test environment: jetpack 5.1.2
Test module: jetpack-Orin-AGX 64G/32G
Test command: fio --bs=4k --ioengine=libaio --numjobs=1 --direct=1 --buffered=0 --iodepth=8 --rw=randread --norandommap --randrepeat=0 --stonewall --exitall_on_error --scramble_buffers=1 --group_reporting --do_verify=0 --name=myjob --size=100% --filename=/dev/sda --ramp_time=5 --runtime=10 --time_based
When running fio random-read performance tests on a USB external drive via the GUI, we see GPU errors in the serial console and the graphical interface freezes—becoming completely unresponsive, with no reaction to mouse clicks on any icons.
[2025-07-29 17:48:40] [ 287.160916] nvgpu: 17000000.ga10b report_pbdma_error:330 [ERR] pbdma_intr_0(0)= 0x04000000
[2025-07-29 17:48:40] [ 287.160922] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:92 [ERR] Error reporting is not supported in this platform
[2025-07-29 17:48:40] [ 287.160929] nvgpu: 17000000.ga10b nvgpu_set_err_notifier_locked:149 [ERR] error notifier set to 24 for ch 506
[2025-07-29 17:48:40] [ 294.338228] nvgpu: 17000000.ga10b ga10b_pbdma_handle_intr_0_legacy:437 [ERR] semaphore acquire timeout!
[2025-07-29 17:48:46] [ 294.338308] ga10b Channel Status - chip ga10b
[2025-07-29 17:48:46] [ 294.338310] ga10b ---------------------------
[2025-07-29 17:48:46] [ 294.338313] ga10b 506-ga10b, TSG: 5, pid 4159, refs: 7, deterministic: no, domain name: (default)
[2025-07-29 17:48:46] [ 294.338315] ga10b channel status: in use on_pbdma, pbdma_busy busy
[2025-07-29 17:48:46] [ 294.338318] ga10b RAMFC: TOP: 8000001ffe16ae74 PUT: 001ffe16ae88 GET: 001ffe16ae74 FETCH: 000000000000 HEADER: 2140006c COUNT: 11110000 SEMAPHORE: addr 002000180000 payload 00000000000001c4 execute 00081003
[2025-07-29 17:48:46] [ 294.338321] ga10b
[2025-07-29 17:48:46] [ 294.338323] ga10b 507-ga10b, TSG: 4, pid 4032, refs: 2, deterministic: no, domain name: (default)
[2025-07-29 17:48:46] [ 294.338324] ga10b channel status: in use idle not busy
[2025-07-29 17:48:46] [ 294.338326] ga10b RAMFC: TOP: 8000002004033d98 PUT: 002004033d98 GET: 002004033d98 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[2025-07-29 17:48:46] [ 294.338328] ga10b
[2025-07-29 17:48:46] [ 294.338329] ga10b 508-ga10b, TSG: 3, pid 4032, refs: 2, deterministic: no, domain name: (default)
[2025-07-29 17:48:46] [ 294.338331] ga10b channel status: in use on_eng not busy
[2025-07-29 17:48:46] [ 294.338332] ga10b RAMFC: TOP: 8000002004053470 PUT: 002004053470 GET: 002004053470 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[2025-07-29 17:48:46] [ 294.338334] ga10b
[2025-07-29 17:48:46] [ 294.338336] ga10b 509-ga10b, TSG: 2, pid 3094, refs: 2, deterministic: no, domain name: (default)
[2025-07-29 17:48:46] [ 294.338337] ga10b channel status: in use idle not busy
[2025-07-29 17:48:46] [ 294.338338] ga10b RAMFC: TOP: 800000200400de88 PUT: 00200400de88 GET: 00200400de88 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[2025-07-29 17:48:47] [ 294.338340] ga10b
[2025-07-29 17:48:47] [ 294.338341] ga10b 510-ga10b, TSG: 1, pid 2282, refs: 2, deterministic: no, domain name: (default)
[2025-07-29 17:48:47] [ 294.338342] ga10b channel status: in use idle not busy
[2025-07-29 17:48:47] [ 294.338343] ga10b RAMFC: TOP: 8000002004033280 PUT: 002004033280 GET: 002004033280 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[2025-07-29 17:48:47] [ 294.338344] ga10b
[2025-07-29 17:48:47] [ 294.338345] ga10b 511-ga10b, TSG: 0, pid 2282, refs: 2, deterministic: no, domain name: (default)
[2025-07-29 17:48:47] [ 294.338346] ga10b channel status: in use idle not busy
[2025-07-29 17:48:47] [ 294.338348] ga10b RAMFC: TOP: 8000002004041ab8 PUT: 002004041ab8 GET: 002004041ab8 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[2025-07-29 17:48:47] [ 294.338349] ga10b
[2025-07-29 17:48:47] [ 294.338352] ga10b PBDMA Status - chip ga10b
[2025-07-29 17:48:47] [ 294.338353] ga10b -------------------------
[2025-07-29 17:48:47] [ 294.338356] ga10b pbdma 0:
[2025-07-29 17:48:47] [ 294.338359] ga10b id: 5 - [tsg] next_id: - -1 [channel] | status: valid
[2025-07-29 17:48:47] [ 294.338370] ga10b PBDMA_PUT 0000001ffe16ae88 PBDMA_GET 0000001ffe16ae74
[2025-07-29 17:48:47] [ 294.338376] ga10b GP_PUT 0000032f GP_GET 00000313 FETCH 00000313 HEADER 2140006c
[2025-07-29 17:48:47] [ 294.338382] ga10b HDR 2001001b SHADOW0 04053448 SHADOW1 00002820
[2025-07-29 17:48:47] [ 294.338384] ga10b pbdma 1:
[2025-07-29 17:48:47] [ 294.338386] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[2025-07-29 17:48:47] [ 294.338392] ga10b PBDMA_PUT 000000d54e69b77c PBDMA_GET 000000cb70133034
[2025-07-29 17:48:47] [ 294.338398] ga10b GP_PUT 00000000 GP_GET c6479080 FETCH 00000000 HEADER c1069980
[2025-07-29 17:48:47] [ 294.338403] ga10b HDR 28f41524 SHADOW0 216069af SHADOW1 6f1216fc
[2025-07-29 17:48:47] [ 294.338405] ga10b pbdma 2:
[2025-07-29 17:48:47] [ 294.338407] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[2025-07-29 17:48:47] [ 294.338413] ga10b PBDMA_PUT 0000006a2c54a714 PBDMA_GET 0000002d18838a90
[2025-07-29 17:48:47] [ 294.338419] ga10b GP_PUT 00000000 GP_GET cda19d5c FETCH 00000000 HEADER 2187c4bc
[2025-07-29 17:48:47] [ 294.338424] ga10b HDR 5116df86 SHADOW0 3ae112f8 SHADOW1 b4b5563a
[2025-07-29 17:48:47] [ 294.338426] ga10b pbdma 3:
[2025-07-29 17:48:47] [ 294.338427] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[2025-07-29 17:48:47] [ 294.338433] ga10b PBDMA_PUT 0000006444535050 PBDMA_GET 0000007aab7ffd40
[2025-07-29 17:48:47] [ 294.338440] ga10b GP_PUT 00000000 GP_GET a0bd8e93 FETCH 00000000 HEADER a107bf5c
[2025-07-29 17:48:47] [ 294.338445] ga10b HDR 64355820 SHADOW0 28995b00 SHADOW1 608317dd
[2025-07-29 17:48:47] [ 294.338447] ga10b pbdma 4:
[2025-07-29 17:48:47] [ 294.338448] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[2025-07-29 17:48:47] [ 294.338454] ga10b PBDMA_PUT 0000007e11766be4 PBDMA_GET 0000007e11766be4
[2025-07-29 17:48:47] [ 294.338459] ga10b GP_PUT 00000000 GP_GET 51f8ffda FETCH 00000000 HEADER 80030494
[2025-07-29 17:48:47] [ 294.338463] ga10b HDR 6be1b5e9 SHADOW0 69c40931 SHADOW1 92721916
[2025-07-29 17:48:47] [ 294.338465] ga10b pbdma 5:
[2025-07-29 17:48:47] [ 294.338466] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[2025-07-29 17:48:47] [ 294.338472] ga10b PBDMA_PUT 000000ef87033400 PBDMA_GET 000000ef87033400
[2025-07-29 17:48:47] [ 294.338477] ga10b GP_PUT 00000000 GP_GET 0dc3e2d7 FETCH 00000000 HEADER e0005c94
[2025-07-29 17:48:47] [ 294.338482] ga10b HDR 08233cae SHADOW0 018b1e9a SHADOW1 ba917c4c
[2025-07-29 17:48:47] [ 294.338483] ga10b
[2025-07-29 17:48:47] [ 294.338487] ga10b ga10b eng 0:
[2025-07-29 17:48:47] [ 294.338488] ga10b id: 3 (tsg), next_id: -1 (channel), ctx status: valid
[2025-07-29 17:48:47] [ 294.338489] ga10b
[2025-07-29 17:48:47] [ 294.338492] ga10b ga10b eng 1:
[2025-07-29 17:48:47] [ 294.338493] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[2025-07-29 17:48:47] [ 294.338494] ga10b
[2025-07-29 17:48:47] [ 294.338497] ga10b ga10b eng 2:
[2025-07-29 17:48:47] [ 294.338498] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[2025-07-29 17:48:47] [ 294.338502] ga10b ga10b eng 3:
[2025-07-29 17:48:47] [ 294.338502] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[2025-07-29 17:48:47] [ 294.338503] ga10b
[2025-07-29 17:48:47] [ 294.338506] ga10b ga10b eng 4:
[2025-07-29 17:48:47] [ 294.338507] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[2025-07-29 17:48:47] [ 294.338511] ga10b ga10b eng 5:
[2025-07-29 17:48:47] [ 294.338511] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[2025-07-29 17:48:47] [ 294.338512] ga10b
[2025-07-29 17:48:47] [ 294.338513] ga10b
Here are the logs captured with a 4 K Philips monitor.
[com COM7] (2025-07-29_173438) COM7 (USB-SERIAL CH340 (COM7)).log (861.1 KB)
Here are the logs captured with a 1 K Philips monitor.
[com COM13] (2025-07-29_104910) COM13 (USB-SERIAL CH340 (COM13)).log (276.0 KB)
