The Orin NX module boot up slowly and the nvgpu driver reports error
Hi
I just got the module and boot it normally after flashing, but it was noticeably slow during the system initialization and installation.
After rebooting, it is stuck at the boot logo for a while, and you can see an error in the log:
[   88.785796] nvgpu: 17000000.ga10b               gp10b_priv_ring_isr:217  [ERR]  ringmaster intr status0: 0x00000000, status1: 0x00000001
[   88.798715] nvgpu: 17000000.ga10b      ga10b_priv_ring_isr_handle_1:684  [ERR]  GPC0 write error: ADR 0x005043f4 WRDAT 0xbadf5900 master 0x0000000b
[   88.812554] nvgpu: 17000000.ga10b      ga10b_priv_ring_isr_handle_1:688  [ERR]  INFO 0x0402020b: (subid 0x00000004 priv_level 0 local_ordering 0)
[   88.826150] nvgpu: 17000000.ga10b      ga10b_priv_ring_isr_handle_1:694  [ERR]  CODE 0xbadf5041
[   88.835203] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:92   [ERR]  Error reporting is not supported in this platform
[   88.847987] nvgpu: 17000000.ga10b ga10b_priv_ring_decode_error_code:542  [ERR]  [Error Type]: client error
[   88.858040] nvgpu: 17000000.ga10b    decode_pri_client_badf50_error:353  [ERR]  [Extra Info]: task protection, value(0x41)
[   88.870828] nvgpu: 17000000.ga10b                     ga10b_bus_isr:105  [ERR]  host pbus fecs error
[   88.880459] nvgpu: 17000000.ga10b                  ga10b_ptimer_isr:50   [ERR]  PRI timeout: ADR 0x00124124 READ  DATA 0x00000000
[   88.892646] nvgpu: 17000000.ga10b                  ga10b_ptimer_isr:60   [ERR]  FECS_ERRCODE 0xbadf5900
[   88.902464] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[   88.915268] nvgpu: 17000000.ga10b ga10b_priv_ring_decode_error_code:542  [ERR]  [Error Type]: indirect source enable violation
[   88.927168] nvgpu: 17000000.ga10b    decode_pri_source_en_violation:448  [ERR]  [Extra Info]: priv_level(0x0), source_ctrl(0x0), source_id(0x0)
[   88.940587] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[   88.953357] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
Can someone explain if this is normal? Thanks. Full log here:
orin-nx-kernel.log (71.0 KB)
Which jetpack version did you use?
I’m using Jetson™ Linux 35.2.1.
This is not from pure jetpack, right? Your kernel and dtb are all built by yourself.
Yes, i’m using kernel sources from the Git server.
I’ll try Jetpack later and give you feedback.
Does the NVIDIA SDK Manager support Orin NX? It’s not in the list.
How should I flash Jetpack?
Please flash it by using initrd flash command.
https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/IN/QuickStart.html#to-flash-the-jetson-developer-kit-operating-software
I just flashed with pure jetpack, now it seems to boot up a little faster, but the nvgpu driver still reports errors after a while. And the UI is still significantly more laggy than the Xavier NX.
Full logs:
jetpack-orin.log (68.2 KB)
Hi @cstdae
Do you have other jetson orin modules that can test?
No, I don’t have more modules. Do you think there might be a problem with the module?
Yes, if that is pure jetpack build and you still see this issue, then I think it could be hardware problem.
