NVIDA RTX Virtual workstation build on AWS not fully compatible with Omniverse
The NVIDIA RTX Virtual Workstation - WinServer 2019 uses Build 17763. This version is not fully compatible with Omniverse applications like View and Create. .An error requesting an upgrade to at least build 18362 occurs when installing and running.
I do not think and in-place upgrade is possible. The windows standard update process does not modify the build version in Windows Server I guess. Would it be possible to get this updated in the AMI so the VM fully supports Omniverse apps, especially for viewing and testing?
Tx
Hi, was considering using this service to get started with Omniverse Development since GPU’s are hard to obtain. Were the issue(s) resolved?
