Nvidia AI Workbench freezes on "Installing and updating packages"
Title; AI Workbench freezes on “Installing and updating packages”. Reinstalling the app, drivers and pytorch does nothing.
OS: Win 11 Version 10.0.26100 Build 26100
GPU: RTX 5090
CPU: Ryzen 7 9800x3d
ai-workbench-support-bundle.zip (39.7 KB)
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
Same issue here . Win11 , already NVIDIA workbench installed as second WSL , but infinite dependencies installation . Tried both NIM setup and AI Workbench setup .
Hello
Sorry you are having trouble.
Which did you try an install first, the NIM Installer or AI Workbench?
Thanks,
Tyler
Try below steps:
Generate a support bundle using the desktop app or CLI (if possible). locate and send the main.log
you can find this under this location.
C:\Users\AppData\Roaming\nvidia-ai-workbench\logs\main.log
Hello !
I believe it was AI Workbench installation .
All the Graces ,
Arhmagos Michael-BasaroS .
Hi, could you please share a screenshot of running the following command in a powershell terminal?
(Get-CimInstance Win32_OperatingSystem) | Select-Object Caption, Version, BuildNumber | Format-List
Could you please also share what your Windows system locale/language is?
This will allow us to see if the the installer may be failing to recognize and proceed with your Windows version string.
Hello !
Sorry for sort of late response , I’ve though that I’ll receive notification via e-mail each time some1 replies to this topic , unfortunately not .
Here is logfile
main.log (4.0 KB)
All the Graces ,
Arhmagos Michael-BasaroS 🤝😇⚖️👨‍💻
Hello !
Yes , sure , here is screenshot :
System language is Russian , since I am from Ukraine non-occupied part . I can change to whatever is needed .
All the Graces ,
Arhmagos Michael-BasaroS 🤝😇⚖️👨‍💻 !
Hi no problem, this is a known defect that will be fixed in our next release, the current workaround should be installing the English language pack and changing your locale to English. I believe you should be able to switch your language pack and locale back after installation has succeeded but this is unconfirmed.
Please view this older thread with the same issue for reference and more detail: Unsupported OS - #23 by taytds10
Quite a simple solution , yet it worked brilliantly !
Much appreciating Your support and efforts 🤝😇 ! ))))
