Can we install NVIDIA Driver OS on NVIDIA Jetson AGX Orin dev kit? if yes, after booting NVIDIA driver OS, can we install Jetpack to it?
Are you talking about “Drive OS”? If so, then it is not able to work on jetson.
Then can you please suggest me how to enable vehicle CAN with JAX orin dev kit? also please what all drivers should be installed on Jetson to enable CAN.
Could you file a new topic and put the CAN request in topic? Someone would guide you about it.
sure, Thanks for the support.
