hi
first history:
installation opensuse 15.6 with nouveau: works as fine resolution is 1920x1080 with cable DVI…
after months works… but now update opensuse (normal, but i read list of update by opensuse there is MESA-driver, Kernel, new updates…for this thing i was remember maybe will issue with Nvidia…) i update opensuse … reboot system… HERE problem is start with nouveau: display is frozen (mouse is frozen) when i open video or firefox (google map globo 3D) so this is issue with nouveau with Card Nvidia (open driver)…
so now i follow installation driver CLOSE Nvidia (RUN)… i follow guide:
NVIDIA the hard way
installation is works, reboot nvidia is actived and nouveau is disactived… works as fine… but resolution display is 1600x900 , i can’t find 1920x1080…from setting system (kde plasma) also from Nvidia Setting there is not list “1920x1080” until there is 1600x900 …i want to know why? how i will resolve this resolution to 1920x1080 …?
opensuse 15.6 KDE 64bit
nvidia gtx 970 nvidia
sudo hwinfo --gfxcard
[sudo] password di root:
61: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.SBJFpfSu2N2
Parent ID: vSkL.by7Pc77zlD9
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "nVidia GM204 [GeForce GTX 970]"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x13c2 "GM204 [GeForce GTX 970]"
SubVendor: pci 0x196e "PNY"
SubDevice: pci 0x1131
Revision: 0xa1
Driver: "nvidia"
Driver Modules: "nvidia"
Memory Range: 0xc6000000-0xc6ffffff (rw,non-prefetchable)
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
Memory Range: 0xc0000000-0xc1ffffff (ro,non-prefetchable)
I/O Ports: 0x6000-0x6fff (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 43 (269786 events)
I/O Ports: 0x3c0-0x3df (rw)
Module Alias: "pci:v000010DEd000013C2sv0000196Esd00001131bc03sc00i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #1:
Driver Status: nvidia_drm is active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #2:
Driver Status: nvidia is active
Driver Activation Cmd: "modprobe nvidia"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #36 (PCI bridge)
Primary display adapter: #61
sudo mokutil --import /usr/share/nvidia-pubkeys/MOK-nvidia-driver --root-pw
EFI variables are not supported on this system
inxi -GSaz
System:
Kernel: 6.4.0-150600.23.17-default arch: x86_64 bits: 64 compiler: gcc
v: 7.5.0 parameters: BOOT_IMAGE=/boot/vmlinuz-6.4.0-150600.23.17-default
root=UUID=542228e9-832a-48b2-b02c-141539733762 splash=silent
video=1920x1080 preempt=full quiet security=apparmor nvidia_drm.modeset=1
mitigations=auto
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
dm: SDDM Distro: openSUSE Leap 15.6
Graphics:
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: PNY driver: nvidia
v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: DVI-I-1 empty: DP-1, DP-2,
DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.11 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,vesa alternate: nouveau,nv
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 75 s-size: 541x304mm (21.30x11.97")
s-diag: 621mm (24.43")
Monitor-1: DVI-I-1 note: disabled res: 1600x900 hz: 60 size: N/A modes:
max: 1024x768 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 550.107.02 renderer: NVIDIA GeForce GTX
970/PCIe/SSE2 direct-render: Yes
xrandr
Screen 0: minimum 8 x 8, current 1600 x 900, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00 +
1600x900 59.82*
1400x900 59.88
1368x768 59.88 59.85
1280x800 59.91 59.81
1280x720 59.86 59.74
1024x576 59.90 59.82
960x540 59.82 59.63
864x486 59.92 59.57
800x600 72.19 60.32 56.25
800x450 59.82
700x450 59.88
684x384 59.88 59.85
640x480 59.94
640x400 59.98 59.88
640x360 59.86 59.83
512x384 60.00
512x288 60.00 59.92
480x270 59.82 59.63
432x243 59.92 59.57
400x300 72.19
320x240 60.05
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
here /var/log
/var/log
important NOTE:
start BOOT (GRUB2) has resolution:1920x1080
after BOOTING (listing system) resolution:1920x1080
start KDE (X11,Xorg) has resolution:1600x900
i try to change NVIDIA X server settings: has not over than 1600x900, there is not list fields:1920x1080. how my resolution is 1600x900 with cable DVI
BUT i have windows 10, installed last version of Nvidia for GTX970, resolution is 1920x1080 with cable DVI.
but begin: nouveau works resolution 1920x1080 without driver (close)NVIDIA…so i change to (close) driver id Nvidia because nouveau has issue frozen,crash after update kernel…
I don’t understand why linux has not 1920x1080 resolution???
please resolve my pc with Nvidia (close)… maybe i need re-install? maybe i need install driver Nvidia other file of RUN (BRANCH)…?
maybe i need downlad
