Nvidia Jetson Nano - A203 V2 carrier - Seeed Studio board flashing issues
I’m using a Jetson Nano through A203 V2 carrier from Seeed Studio. Initially, I was able to flash the board using the SDK Manager from Nvidia. Recently for testing purposes, needed to reflash the module and I’m not able to flash on through command line or SDK Manager.
I’m not able to load the module to Force Recovery Mode and I’m not able to view the board being detected in linux host with the command “lsusb”. Neither is the board being detected by the SDK Manager.
you should contact the vendor for issues about flashing custom carrier boards.
But if you cannot even put it in RCM, by placing a jumper, then I think it’s some hardware failure.
