Hello, I bought separately an nvidia JETSON-IO-BASE-A from aliexpress thinking it’s the full development kit but turns out the nano module itself was missing, so I purchased the 4gb nano module as well. After assembling them and powering the unit, the power led is solid red and the display powers on but remains dark. I know it should be solid red and it should boot into the nvidia custom ubuntu. I tried to use a 20W power adapter and it still didn’t work. Is it a compatibility issue or a hardware issue? Is there anything else I can try?
I will leave the links I used to purchased the components just in case:
IO board: https://www.aliexpress.com/item/1005004242210782.html?pdp_npi=2%40dis%21RON%21RON%20491.50%21RON%20383.36%21%21%21%21%21%402101f6b716672283210407942ea7ec%2112000028498466695%21btf&_t=pvid:d54433f3-1e0e-4296-b46a-78be1a5a944b&afTraceInfo=1005004242210782__pc__c_ppc_item_bridge__xxxxxx__1667228321&spm=a2g0o.ppclist.product.mainProduct
Jetson Nano Module: https://ro.farnell.com/nvidia/900-13448-0020-000/nvidia-jetson-nano-module-arm/dp/4126467
