Hi, I have a Jetson Nano 4Gb, which I could use it successfully after following the official trainings.
Looking for next improvements I wanted to add the Intel WIFI module called 8265NGW, but after mounting this, all my USB ports had stopped working. I could read here some discussions about this issue that happened for others, but it’s still not clear for me what is finally the solution. This WIFI module is just damaging the board?
I tried also to re-flash the SD card but the problem is still there.
Can you please help me with some information?
To power the board I used the microusb / barrel jack power 4A
