Hi Guys,
Have any of yous be able to run NVIDIA optical flow SDK on Jetson Xavier? I’m having issues to build the library for aarch64. I’ve downloaded the Video Coded from NVIDIA as well, which is where the problem is happening.
The architecture seems to not be supported. Do you guys have some precompiled version for Jetson Xavier?
The error I have when building is:
Video_Codec_SDK_10.0.26/Lib/linux/stubs/x86_64/libnvcuvid.so: error adding symbols: File in wrong format
The cmake command line:
cmake -DVIDEOCODEC_SDK_ROOT=${HOME}/dev/third_party/Video_Codec_SDK_10.0.26 -DOpenCV_DIR=${HO ME}/dev/third_party/opencv/
System: JetPack 4.4 on Jetson Xavier AGX
Thank you a lot for any clue.
BR,
Sidnei
