Nvidia sync
connection error: is something running on port 11000? The apps locate in the sync can not be open, i can’t even open custom to put the port for open webui. I am only open the NVIDIA sync on my DGX Ubuntu OS. I do not know if because of that I have problem to install vscode on Ubuntu.
Hi, can you open the dashboard on the Spark locally when you connect a monitor?
Yes, I am able to open Dashboard on my spark locally when connect to monitor. should I only install nvidia sync on different OS? Hope it does not cause other issue with my spark.
NVIDIA Sync is designed to allow easier connection to your DGX Spark from another system. We have downloads for Windows, Mac, and Debian based Linux systems. You should not be installing it on your Spark unless you want to connect to a different Spark.
Alright thanks gonna remove it to see if anything change.
should I remove nvidia sync and nv AI workbench from my spark?
You should remove NVIDIA Sync from the Spark, I don’t think you need to remove AI workbench though
thanks will rm nv sync.
