NVMe SSD interface and mini-SAS cable for strage extension of Orin
Software Version
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[*] 1.9.2.10884
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
I want to know how to connect SSD to orin. Especually, I want to know the right Mini-SAS cable spec and NVME SSD interface spec for Drive AGX Orin.
I saw the following comment.
The following comment shows the devkit follows Open Compute Facebook version of the Mini-SAS spec.
  1. Doen NVMe SSD interface require U.2 interface?
  2. If #1 is true, could you tell me the right cable to connect U.2 SSD to Orin devkit?
    I can find the following Mini SAS HD SFF-8643 - U.2 U2 SFF-8639 cable. Does it work?
    Amazon.co.jp: chenyang PCIe 4.0 SFF-8643 - SFF-8639ケーブル SATA電源付き U.2 SFF-8639 NVME SSD マザーボード 内部拡張 1.64フィート/0.5M : Computers
  3. If #1 is false, could you tell me the suitable interface of NVME SSD and how to connect to Orin devkit?
PCIe (Mini-SAS) could connect to external storage but it need dedicated designed adaptor board.
USB3 PD is easier to access.
@JimWang Thanks!
Could you tell me the model number of “dedicated designed adaptor board”?
I know USB3 PD is easier to access, but R/W speed is slower than PCIe IF.
Or, does Drive AGX Orin devkit have M.2 interface for NVMe?
Hello, @JimWang could you tell me:
Orin devkit has J2, J3 data recorde connectors, which connect M.2 NVMe through PCIe and have necessary power/GPIOs.
If want connect M.2 NVMe through Mini-SAS, need design a similar PCIe-to-NVMe adaptor board, not ready-made one.
Is #2 is verified already. No information if this cable is Open Compute faceBook version of Mini SAS Spec
Hi @kayccc ,
I have connected USB3 SSD to Orin via PD port. But it’s poor performance as follows:
nvidia@tegra-ubuntu:/media/sda1_EXT_NVME$ dd if=/dev/zero of=1GB.dat bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 6.42101 s, 167 MB/s
Could you tell me how to use USB SSD on Orin faster?
USB 3.0 up to 5Gbps (625MB/s) in theory, but real-world R/W perf limited by many other factors.
167 MB/s match with USBSS real R/W performence.
lsusb shows 10Gbps connection b/w Orin and USB SSD. In case of HOST PC with USB SSD, then around 600MB/s result is shown.
$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 3: Dev 2, If 0, Class=Mass Storage, Driver=uas, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
Hi @kayccc
Is there a documentation that would help us to connect M.2 NVMe SSD with J2 and J3 data recorder connectors?
Please open a new topic for your question. Thanks
