Software Version
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.2.10409
other
Host Machine Version
other
I want to use a miniSAS cable to communicate between two NVIDIA DRIVE AGX Orin Devkits(Hereafter, it is abbreviated as DDPO).
So I connected two DDPO with miniSAS cables and operated them according to the instructions in the URL below.
Unfortunately, DDPO configured as PCIe Root Port did not recognize the other DDPO configured as PCIe Endpoint as a PCIe device (DDPO configured as PCIe Root Port does not show Device ID for DDPO configured as PCIe Endpoint after entering lspci command (Linux command)).
Please answer the following questions.
Question1
Has there been a track record of communication between two DDPO using miniSAS cables?
Question2
Do I need to update PCIe Retimer FW?
Question3
Do I need to change the Device Tree?
Also, do I need to update AURIX FW?
Question4
If there is any additional work that needs to be done, could you tell me specifically?
